Old 04-14-2017, 11:33 AM   #51
_Ogre
_Ogre's Avatar
Re: Installing Deluxe trim on cab
Originally Posted by joedoh View Post
I installed bed trim on a 65 C10 with the 3m tape and it was easier done than said.
i was just thinking the same thing as i read thru this thread, you wouldn't even need the holes
for making a backer for the tape to stick to i'd think body filler would work well
the shape of the trim would lock in the filler, even if it cracked every 1 inch
we use the grey tape (joedoh refers as vhb) for body kits and window louvers
use of the 3m adhesion promoter would guarantee a permanent bond
shop air compressor timer
Old 04-14-2017, 12:17 PM   #52
joedoh
joedoh's Avatar
here is newfishers how to, I followed it except I only used spacers and tape about every foot.
http://67-72chevytrucks.com/vboard/s...2&postcount=23
Old 04-14-2017, 02:17 PM   #53
Dan in Pasadena
Dan in Pasadena's Avatar
^^^This^^^ is great info.
I really love the deluxe trim but i just couldnt wrap my head around drilling holes in my newly restored and painted cab. I'm going to have to reconsider now.
If any of you does this PLEASE take detailed photos of it and especially if you run into any hangups doing it. Thanks to Newfisher and of course to JoeDoh for remembering it and posting the link here.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 04-14-2017, 06:10 PM   #54
Russell Ashley
Russell Ashley's Avatar
The last time I was at the auto paint store I saw a display of various clips and they had some wire clips that had the rubber seal on them. If I was still thinking of using wire clips I would go back there and see if I could find something that would work. I've decided that I'm not going to drill holes to mount the trim so I'll leave it off until I figure out some way to hold it on. I'm going down to see my son next week and get his advice about it.
Russell Ashley is offline   Reply With Quote
Old 04-15-2017, 11:11 AM   #55
_Ogre
_Ogre's Avatar
that's a good idea for straight trim, which our cab trim is not
Old 04-15-2017, 04:32 PM   #56
Oldtruckwelder
Oldtruckwelder's Avatar
After reading this thread I had to open the trim kit that was bought in the 80's to see if the clips would hold the trim tight to the truck. After temporarily installing trim to drivers door, clips were found to be correct size and held tight to body. They appear to have a fabric or foam adhered to the clip. I have 48 holes in total on cab, and 46 clips were supplied with kit.
Oldtruckwelder is offline   Reply With Quote
Old 04-15-2017, 04:38 PM   #57
Oldtruckwelder
I know most of you have seen this in the assembly manual, but if you haven't
Good info for sure.
Old 04-15-2017, 07:26 PM   #58
Oldtruckwelder
Well the clips fit good, but I was given two top rights and two bottom lefts for the back of the cab. After all of these years protecting that dang cardboard box . I remember getting them from the truck shop of orange California at the charlotte auto fair in the late 80's.. if anybody out there got the other set that was mess up look me up., LOL LOL
JT from SC
Old 04-15-2017, 07:56 PM   #59
joedoh
joedoh's Avatar
you could
1. use a heat gun on the lexan spacer, lexan is really nice to work with heat, it turns into a noodle. this would let you run a continuous strip of tape if that were the desire.
2. you could do it the way I did it and attach the tape only in small sections. curves be damned, it would work that way.
like I said, it was easier done than said, I was done with the bed in minutes once I had some spacers cut.
Old 04-15-2017, 10:22 PM   #60
Dan in Pasadena
I'm thinking the modern badge tape would work fine for our purposes. Even though the tape will be narrow behind this trim, the number of linear inches would be plenty I would think.
Old 04-16-2017, 10:19 PM   #61
Port&PolishMan
Port&PolishMan's Avatar
I Think I would have Added - Thin Teflon Circles with a
Cross Cut Center with Main Vertical Cut going out the Bottom of Circle
to Act as the Slip On . . .035 Material - should do it Up Fine .
Would Act as a Cushion to the Steel - Quieter - and Plug the Hole ..
Just a Thought . .
Port&PolishMan is offline   Reply With Quote
Old 04-19-2017, 07:22 PM   #62
Oldtruckwelder
Any truck builders out there got any 55-59 deluxe cab s/s trim pieces or kit they would like to get rid of.
Thanks JT from SC
Old 04-29-2017, 04:55 PM   #63
Gribbs
Gribbs's Avatar
Thanks JT from SC
P.O. drilled holes in the bottom pieces of my BBW trim. A local shop says he may have pieces, but I have yet to go try him. If he doesn't, I'll be ordering a full set of trim and only need the bottom pieces (I think my stock other pieces are not tweaked) and then I could sell other pieces I don't need. Send me a PM because i'll be working out trim in next month or two for sure to finish off my build.
Thanks to all who contributed to this thread. I'm dreading buying the wrong clips and this is helping.
Gribbs is offline   Reply With Quote
Old 04-29-2017, 08:33 PM   #64
Foot Stomper
Foot Stomper's Avatar
Just today I took all the clips off my stainless. Took some pictures too. I've counted the rusty images on the back of the trim and I count 42 spots plus 2 spots for the figure 8 clips plus 2 more spots for the bolt clips that hold the trim on the door(s) for a total of 48 spots.
For what it's worth, here are some pictures.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 04-30-2017, 12:13 PM   #65
Coupeguy2001
Coupeguy2001's Avatar
I bought a taped together bundle of stainless. enough to do 3 trucks for $35 at a swap meet.
all the clips were in a plastic bag. sadly, none of the stainless is perfect, but I used a small rubber hammer and some tongue depressors taped together to massage some of them back to almost normal
If you didnt look at the other side of the truck, you would think they were perfect.
Coupeguy2001 is offline   Reply With Quote
Old 10-10-2018, 10:32 PM   #66
tdishon
Reviving this thread.
I tried the aftermarket ones and they are a far cry from the original. Does anybody have any good originals?
Current project: 59 Apache with 2012 Corvette drivetrain
Jeep Trackhawk(beast)
tdishon is offline   Reply With Quote
Old 10-10-2018, 10:42 PM   #67
Gribbs
Gribbs's Avatar
I have half original and half aftermarket trim on my doors/cab. The trick is having the right clips, or you will dent the aftermarket pieces too easily.
Buy a bag of clips from Bills Trucks up here in Canada. He also sells the trim and it comes with clips, but they blow, and the clips they sell in a baggy are perfect. PM me for more info. I’m lucky to live five mins from that shop
Old 10-10-2018, 11:33 PM   #68
Foot Stomper
I bought the ones from Bill's too, and they worked perfectly.
Old 10-11-2018, 01:58 PM   #69
BBPanel
Originally Posted by Gribbs View Post
....Buy a bag of clips from Bills Trucks up here in Canada. He also sells the trim and it comes with clips, but they blow, and the clips they sell in a baggy are perfect. ....
Are these the clips you are referring to:
24-304-CR clip kit for cab trim–fits OE trim only (NO water seal on clip) 50 piece kit 55-59 $22.95
page 65, http://www.billstruckshop.com/Catalo...0%20Master.pdf
BBPanel is offline   Reply With Quote
