Old 06-28-2020, 01:26 PM   #1
3x2GTO
G 50 spring option 1976
My '76 C 20 has it's original 56" G 50 HD rear springs and 1 of them is broken, so I'm replacing both. Any idea as to what lb spring the G50 option was? I'm looking at General Springs and they have several options available. I only use the truck to pull a loaded 22' car trailer with a 7,000 lb GVWR.
3x2GTO is offline   Reply With Quote
Old 06-28-2020, 05:53 PM   #2
sweetk30
sweetk30's Avatar
Re: G 50 spring option 1976
how many leafs in the pack ? and the overload on the bottom is a given .
7+1 or 8+1 or 9+1 ? the +1 is the overload .
i like my 22-547 springs . nice lighter ride . and i put in timbren bump stops for when i am loaded heavy .
posted just for the spring specs info on the part # i posted up . https://www.sdtrucksprings.com/index...oducts_id=7356
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 06-28-2020, 10:07 PM   #3
3x2GTO
My original springs are 8/1, a little less than a 3" spring pack, I'm guessing they're rated at 2600lbs? Just wanting a simple spring setup, no over loads or bump stops, I don't mind a little stiffer ride when M/T. I ended up with a new set of 9/1 General Springs #22 617, rated at 3955 lbs, 4 1/16 pack. I think that may really affect the ride when empty though.
Old 06-29-2020, 08:32 AM   #4
sweetk30
sweetk30's Avatar
you will know there in there . . .
you can always pull a leaf or 2 per pack . but space them apart if you do . dont pull 2 direct leafs . ex: #3 and #4 . . . go #3 and #5 that kind of spacing .
Old 06-30-2020, 10:13 PM   #5
3x2GTO
I talked with General Springs today and they said that their 2600 lb spring was the same as the GM G 50 HD spring option, and their 3500 lb was custom and never offered thru GM, it would also raise my vehicle a little, so I ended up ordering the 2600. Thanks for the replies.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
