Old 10-23-2016, 04:18 PM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
E brake
So i need help with 65 project both front and back e cables are just hangin down i tride connecting them but theres a good size gap inbetween what am i missing??any help is appreciated thx .even some pics of your set up will be helpfull thx
1966FLEETSIDE is offline   Reply With Quote
Old 10-24-2016, 01:30 AM   #2
Captainfab
60-66 Nut
Re: E brake
Do you have the crossmember with the e-brake linkage in place?
Old 10-24-2016, 08:52 AM   #3
1966FLEETSIDE
Re: E brake
Capt.fab no i dont.aha thats whats missing!you know where i can find one?
Old 10-24-2016, 09:03 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: E brake
Here is a link of what your looking for: http://67-72chevytrucks.com/vboard/s...d.php?t=379268
A place to buy: http://www.aspenautoaz.com/60-66-chevy-truck-parts.html
" 1963-65 Emegency brake pivot crossmember complete $100.00 "
The crossmember is riveted to the frame rails so getting it out is a chore. You can use (I think) 7/16" grade 8 fasteners to put it back in.
If you want to go aftermarket here is a link with info on that: http://67-72chevytrucks.com/vboard/s...d.php?t=562185
Old 10-24-2016, 04:54 PM   #5
Backpayne
Re: E brake
Are you set on keeping it factory? I used Lokar universal cables and they were super easy to set up.
Backpayne is offline   Reply With Quote
Old 10-25-2016, 06:27 PM   #6
mafosa
Re: E brake
most arent going to like mine. i went in a different direction.
https://www.youtube.com/watch?v=SFZ6KFcSV_U
larry
mafosa is offline   Reply With Quote
Old 10-25-2016, 07:53 PM   #7
The Rocknrod
Moderator
Re: E brake
Ya, mines gonna be electric.
Old 10-25-2016, 11:48 PM   #8
'63GENIII
'63GENIII's Avatar
Re: E brake
Are you looking for the crossmember and the linkage or just the linkage?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-27-2016, 09:38 AM   #9
1966FLEETSIDE
Re: E brake
63 genni just the crossmember
Old 10-29-2016, 05:26 PM   #10
sixty4bigwindow
sixty4bigwindow's Avatar
Re: E brake
So I have the cables from both drums, to the plate in the middle, complete. But I don't have the x-member or any of the parts along with that. Then from the front, I have the lever in the cab, and the cable down towards the middle from there... Will the lokar lever replace everything in the front, and connect right up to the 2 cables in the back? And do you have a link for the best one to use? I don't care about keeping it original, I just want the safety of the emergency brake! Thanks for any help
sixty4bigwindow is offline   Reply With Quote
Old 10-29-2016, 07:09 PM   #11
'63GENIII
'63GENIII's Avatar
Re: E brake
The linkage can be fabbed fairly easily. I have a cross member with the anchor point for the linkage if you want. If you cover the ride, it's yours.
Chris
Chris
'63 k15 long step
Old 10-29-2016, 08:33 PM   #12
sixty4bigwindow
Re: E brake
But don't I still need the x member to mount it to? The turbo 400 tranny takes up the whole area of that member right now.. wouldn't it be easier just to run a Lokar setup from the cab to the existing cables I have?
Old 10-29-2016, 08:44 PM   #13
'63GENIII
'63GENIII's Avatar
Re: E brake
Let me get a pic tomorrow and see if it's what you need.
Chris
'63 k15 long step
Old 10-30-2016, 12:54 PM   #14
'63GENIII
'63GENIII's Avatar
Re: E brake
Here is what I have. one is an auto x member and Im guessing the other is a manual. Not sure what the Lokar set up looks like. It may be easier than returning to stock.
Chris
'63 k15 long step
Old 10-30-2016, 07:05 PM   #15
sixty4bigwindow
Re: E brake
Hmmm I think it is easier going to lokar. But I'm just not air which setup will run with the current system lol. Guess I'll do some more research! Thanks a ton for the pics and the input tho! Pretty much solidified I want to not go back to the stock setup lol
Old 10-30-2016, 07:33 PM   #16
Backpayne
Re: E brake
This is what I used: http://www.lokar.com/product-pgs/ebr...ke-cables.html
It connects to the pull handle cable.
Old 10-30-2016, 11:23 PM   #17
sixty4bigwindow
Re: E brake
So the bracket connecting the 2 cables just bolts to the stock pull handle, and the cables connect to the stock cables that would normally be connected to the x-member?
Old 10-30-2016, 11:45 PM   #18
Backpayne
Re: E brake
Here is how mine looks. I just installed a new front cable (connects e-brake lever to Lokar cables) as it broke last week. The Lokar cables run along the trailing arms and connect to brakes like factory. Super simple!
Old 10-31-2016, 02:58 AM   #19
Heater63
Heater63's Avatar
Re: E brake
I too have an extra stock crossmember out of a '63 if you need it (Like 63 GenIII)
The setup I did is like BackPayne's, except I'm using an electric E-Stopp instead of a manual front cable.
If you need custom cables made, I had good results using these guys:
http://www.controlcables.com/
good luck.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 10-31-2016, 08:27 PM   #20
sixty4bigwindow
Re: E brake
So payne, i can connect that lokar cable to the original lever, but then run it all the way to the brakes?? Or can I use the original rear linkage and run it to this lokar setup?
Old 10-31-2016, 08:32 PM   #21
Backpayne
Re: E brake
The cable from the handle that runs through the firewall connects to the Lokar setup, which runs to the brakes.
Old 10-31-2016, 10:13 PM   #22
Backpayne
Re: E brake
Here is the cable that runs from lever under steering wheel to the gold block of the Lokar cable: http://autoplicity.com/3735860-dorma...ngComNOFITMENT
Old 11-01-2016, 12:22 AM   #23
sixty4bigwindow
Re: E brake
Awesome thanks a ton for the info and links!! I'm gonna get started on this as soon as i bend all my new brake lines for the disc conversion lol
Old 01-13-2017, 08:58 PM   #24
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: E brake
i almost forgot Aspen. I've had good success buying from them.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
