Old 11-22-2020, 10:04 PM   #126
May70
May70's Avatar
Re: Project: Montezuma
If that is the cause then I can just put spacers on the mounts to level it out with the rest. I might be able to compare that measurement between the new and old pan, but the old pan is pretty rough.
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to metal work videos
https://www.youtube.com/channel/UCkS..._as=subscriber
May70 is offline   Reply With Quote
Old 11-22-2020, 10:15 PM   #127
May70
May70's Avatar
On to the DS...
Think ive finished up the pillar. Next move is to make the final cut on the cab corner and make sure everything still where I want it.
Video taped it and will upload it to the channel.
Old 11-22-2020, 10:47 PM   #128
Scurry67
Great work on all that metal work! I’ll be following along both on here and the vids. Keep up the progress!
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 11-24-2020, 05:56 PM   #129
May70
May70's Avatar
Okay! Got the cab corner cut to fit and mocked up nicely. Threw on the outer rocker and that is a MUCH better start then I had on the PS....
Burnt in the pillar and cleaner it up so I can seal it in place tomorrow and prepper the cab corner for sealing also. Tomorrow is the warmest day I have coming so I figured id use it...
After I get this all sealed and back together I should be about ready to post the video footage since the previous update. Moving right along....
Old 11-26-2020, 09:51 AM   #130
JAKA
Wish I would've found this thread sooner. I also bought the high hump floor pan and have the same issues. I would've went with the regular floor pan instead. I chose a different route and bought another cab that's solid and doesn't need all the rust repair. I'm now trying to decide what I want to do with my original cab. Repair it all at a later date, sell it with what repair panels I have or part it out. Very informative post and keep up the good work. Thanks
JAKA is offline   Reply With Quote
Old 11-27-2020, 07:03 PM   #131
May70
May70's Avatar
Read over the paint info and it requires no less than 65 for 24 hrs.... Well I couldnt hold off progress anymore so I borrowed two space heaters. Used the propane heater to get garage up to temp and the space heaters to maintain that area...
I jammed a screw driver between the pillar flange and the floor pan so I could get sealer between them.
Tomorrow ill be ready to tack the cab corner in place and keep rollin
Old 11-27-2020, 07:09 PM   #132
May70
May70's Avatar
I also deleted the gas filler hole and cut out some of the firewall to fill....
Old 11-28-2020, 12:45 AM   #133
KMC3420
KMC3420's Avatar
Looking good. Glad you were able to spray some epoxy. The temps are slowly getting lower and staying there. I am at the same spot as you, however I need to sandblast and epoxy my cab corners but don’t see any 60+ degree days in the near future. Keep the progress moving.
68 SWB C-10 original 350 A/C
KMC3420 is online now   Reply With Quote
Old 11-28-2020, 10:15 AM   #134
May70
May70's Avatar
Yeah you are doing your work outside right? Might be problematic........ I saw some guys who use a cheap(ish) enclosed car tent and a propane heater. Definitely not efficient but it gets it done for them.
Also once it flashes you can always try the old heated blanket trick...
Old 11-28-2020, 11:49 AM   #135
KMC3420
KMC3420's Avatar
Yes, outside unfortunately. I am to the point I will likely haul it to where I am storing my frame, but might try to get a bit more done first. I have thought about the tent option but feel it would be a cluster. Trying to just be patient! Yours will be buttoned up pretty quickly!
Old Yesterday, 12:14 AM   #136
May70
May70's Avatar
Drivers side cab corner tacked in place.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
