Old 04-08-2021, 11:40 AM   #1
jaxncurtis
Fresh New Engine - Need help trouble shooting
Hey guys, I just installed a fresh new 250 inline 6 engine. Started it this last week and did the first breakin and was able to get the timing set pretty much perfect. She runs GREAT!!
I never put it in gear to drive it... up until today...
I put it in gear and the truck will not go any faster than 5mph with the pedal to the floor!!
What could be the issue here? Do I have the kickdown cable two loose? Too tight? Anything else you can think of?
Im certain nothing is wrong with engine as it is running great!
Im new to installing engines so please bare with a newbie...
jaxncurtis is offline   Reply With Quote
Old 04-08-2021, 12:34 PM   #2
kwmech
Re: Fresh New Engine - Need help trouble shooting
Left the parking brake on? plugged exhaust?
Old 04-08-2021, 12:43 PM   #3
jaxncurtis
I check parking break that is off... Rolled down drive way with no problem...
No exhaust, just headers at the moment. Was on the way to go get mufflers!!!
Old 04-08-2021, 02:14 PM   #4
SeventyOne
Do you have fluid in the trans?
SeventyOne is offline   Reply With Quote
Old 04-08-2021, 07:08 PM   #5
1rippen6
If the converted slide out and you didn't reseat it, it's possible that you jammed it into the pump. Ask me how I know, experience from my first tranny install years ago.
1rippen6 is offline   Reply With Quote
Old 04-09-2021, 09:08 AM   #6
litebulblsc
litebulblsc's Avatar
What does it do when you give it more gas- does the engine speed up or stay flat?
It sounds like it is an automatic transmission. If it is a TH350, it will operate without the kick down cable. I doubt its adjustment is your issue, but you can disconect it temporarily to eliminate the possibility.
But at this point, I would advise against trying too much without verifying it is not something more serious first.
The more info and any pictures you can post could possibly help to figure out the issue.
litebulblsc is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
