Old 04-24-2023, 09:46 PM   #1
ShinyC10
Wheeeels
So I pulled the trigger on the stage 1 air ride kit from AZproperformance for the 73-87 model truck. Front consists of the plates/cup with the bags with the stock control arms and the back is a bolt in 4link from ridetech. I got some Vannatta front inner fenders coming in in a few weeks. I got my eyes on some wheels (us mags boulevard 20x9.5 and 20x8). Curious if the back spacing is going to be an issue with these. 20x8s come with a 4.54bs and the 20x9.5 with a 5.29bs. Back has stock tubs and bed floor. Any help is appreciated, thanks 👍🏻
ShinyC10 is offline   Reply With Quote
Old 05-02-2023, 09:38 AM   #2
SCOTI
SCOTI's Avatar
Re: Wheeeels
They should 'fit' fine assuming stock width rear end housing & un-modded (narrowed) front arms.
My personal preference is 5"BS minimum on an 8" front wheel. It offers more turning clearance @ the fender-lip when the truck is LOW & keeps the track width to a minimum. Your proposed 8's w/4.5xBS just has less clearance @ that outer plain/fender lip.
(Full disclaimer: 5"BS up front usually has increased interference issues @ the a-arm which requires more effort)
I'd prefer 5"BS on a 10" wheel out back which would be the same as 4.5"BS on your proposed 9.5" rear wheel. The additional back-spacing @ 5.29" will tuck the rear wheels more than needed to clear which impacts looks but they'll still fit/work. They could come very close to the edge of the inner tub/floor seam so I'd watch for possible interference. if so, a .250" spacer would likely be all that you'd need.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-19-2023, 12:08 PM   #3
ShinyC10
Re: Wheeeels
So is there anything against running that set up and just putting a half inch spacer on the front?
With the specs you listed, there’s not really a large selection of wheels unless you have a $10,000 budget it seems. Wheels and tires I’m trying to stick around 4 to 4500 max.
Old 05-19-2023, 04:58 PM   #4
SCOTI
SCOTI's Avatar
Re: Wheeeels
Not sure why you would want the 1/2" spacer up front? The 8" wheel w/4.54bs works as is. Adding a spacer brings it closer to the fender lip which you won't want.
If anything, you might need a 1/2" spacer in the rear to clear the inner wall of the wheel tub and/or edge of the bed floor. My bet is it should clear w/o one.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-24-2023, 07:55 PM   #5
ShinyC10
Re: Wheeeels
Okay, so I had my eye on another wheel a little out of budget but f it, if it has more options then it’s worth it in my eyes. American Racing Gasser wheels offer 20x8.5,9,10 and 10.5 with almost any backspacing. What’s an ideal bs for 8.5 or 9” front wheel and a 10/10.5 rear wheel with stock bed, axle and air ride with a c notch.
Old 05-24-2023, 11:18 PM   #6
SCOTI
SCOTI's Avatar
Re: Wheeeels
For 8.5's up front, I'd want 5-5.25bs.
For 10's out back, I'd want 5.00bs. If 10.5's, I split the diff if possible or stick w/the 5.50" & dial it in as needed w/some .125/.187/.250" spacers.
Put a wheel on there that you can reverse engineer your calcs with. If you have a known starting point, calculating from there helps provide a real time number range for your specific truck.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-25-2023, 02:50 PM   #7
Loco83
Loco83's Avatar
Re: Wheeeels
This should help you out.
http://thewheelsmith.net/wp-content/...nt-Article.pdf
Loco83 is offline   Reply With Quote
