01-17-2019, 12:39 AM | #1 |
72 C10 payload
Hey all,
Lurked around getting info here for awhile, great bit of reading I will admit. My issue is this, can I raise my payload capacity by getting different coils on my truck? I use it as a DD but i do actually haul loads most of the time. Maybe my originals may be worn out but I loaded it today with 1 4x8 3/4 ply, 12 2x6 8ft, and maybe 16 2x6 4ft. I was gonna keep adding but she squatted down to just below level and it is stock height. Any advice is welcome. Thanks and keep that info flowing. |
01-17-2019, 10:33 AM | #2 |
Re: 72 C10 payload
There are heavy duty rear springs out there, as well as helper air bags that fit inside your existing springs, and the old stand by air shocks.
Do some searching in the suspension part of the forum and that should give you more information. Welcome to the forum, lots of good people and info here.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-17-2019, 10:47 AM | #3 |
Re: 72 C10 payload
Short answer to stiffer coils is yes....Comes with a stiffer ride most likely. Replace with simular to originals and all the things, Clay 68c10 said....Welcome aboard...post some photos.
01-17-2019, 04:55 PM | #4 |
Re: 72 C10 payload
There were factory overloaded springs available with the HD spring opinion. The 67-72 version was a single leaf and the earlier trucks were multi-leaf. Using these or a helper air bag system would allow you to have the 1/2 ride with an increase in hauling capacity. These seem to come up for sale regularly in the classified sections or if your lucky at a local junk yard.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-18-2019, 03:22 PM | #5 |
Re: 72 C10 payload
So that single spring in the first picture is something I can add to mine I believe. My truck had the leaf brackets on it when I bought it but I have removed one side already to add a frame mounted hitch. Might have to get that put back on and not use a hitch, or figure a way around it. Thanks for that info 455
Posted via Mobile Device |
01-18-2019, 06:24 PM | #6 |
70+ ( Old Skool Club )
Re: 72 C10 payload
From what you staed your nedds are I agree the factory overload springs along with a good set of shock absorbers should work for you. I have the overloads on my truck and new shocks and I have occasionally hauled heavy stuff and the truck doesn't squat.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-18-2019, 08:13 PM | #7 |
Re: 72 C10 payload
3-400 Lbs. of lumber should not bottom your springs. You need new springs period IMO.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
01-19-2019, 09:11 PM | #8 |
Who Changed This?
Re: 72 C10 payload
Yup! I know a farmer in Idaho who had the bed of his truck (C/10) filled with grain. About 2 tons. It was riding on the bump stops. He stopped at the shop I was working at to get a tarp from his son so the grain wouldn't blow out too much. He drove that thing about 8 miles to his farm like that...at about 5 MPH.
01-19-2019, 09:26 PM | #9 | |
Re: 72 C10 payload
1969 Chevy c20(Miss Hackjob) |
01-20-2019, 10:27 PM | #10 |
Who Changed This?
Re: 72 C10 payload
Then again, I was putting an addition on my previous house. I went to the BORG and got a ton of shingles and loaded it in the back of my '56 Chevy 210 wagon. I drove slowly going home, because the headlights were looking at treetops, and I could steer it with one finger (no power steering). The way we sometimes abuse our vehicles.
01-23-2019, 12:23 AM | #11 |
Re: 72 C10 payload
I thought a simple method was to also replace with c20 springs? They are rated higher and will be stiffer but should be easy to swap out.
