05-19-2017, 10:14 PM | #1 |
Where does this go?
I can't remember where this belongs and can't see it in any of the photos that I took. It's not the piece that straddles an intake runner near the front of the engine on the drivers side, as I have already put that piece on. I took a lot of pictures as I tore my truck down, but I should have taken more from multiple angles. I assume it goes on top of the engine some where, that's why I painted it along with other engine pieces. Any help would be appreciated.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
05-19-2017, 10:20 PM | #2 |
Re: Where does this go?
passenger rear intake manifold bolt. Used for lifting engine
Fuzzy |
05-20-2017, 12:16 AM | #3 |
Here's a picture for reference
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
05-20-2017, 12:24 AM | #4 | ||
"I ain't nobody, dork."
Unless you're doing a full on restoration... it's not needed.
Gary
05-20-2017, 01:28 AM | #5 |
I recall having at least one. Nice way to pull an engine I'd say, especially with a leveler.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-20-2017, 09:03 AM | #6 |
They don't work well if you use a single chain to lift the engine, they will bend. I know that's not what they did at the factory.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
05-20-2017, 11:00 AM | #7 |
If I get your meaning, that's because of the force too close to a 180 angle. These require a 90, or near anyway.
05-20-2017, 11:27 AM | #8 |
From what I understand, the assembly line used a spreader bar with pins that go in the holes in the brackets, so all the lifting force is straight up. I tried lifting mine with a chain hooked between the two brackets and lifting in the middle. It caused the brackets to bend to the center of the engine. Obviously not ideal. They would work pretty well if you could rig up some sort of spreader between the brackets.
05-20-2017, 11:38 AM | #9 |
Load leveler works well with these lift points.
05-20-2017, 11:44 PM | #10 |
I picked up similar, package deal on a hoist.
06-12-2017, 08:00 PM | #11 |
Say, came across the lift bracket(s) off my 71. I knew I'd seen these. Couple questions/observations illustrated by the picture. Any knowledge appreciated.
Edit. At another look, none of mine are like the OP. Only one is like post 3.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-12-2017 at 11:12 PM. |
06-12-2017, 09:46 PM | #12 |
I install em if have em - if I don't, I feel like I'm saying, 'go ahead, I dare ya to have to be rebuilt any time soon....' And the engine always wins.
06-12-2017, 10:36 PM | #13 |
Active Member
The bracket with one bolt hole mounts on the back of the passenger side head
in the bolt hole closest to the intake manifold. |
06-12-2017, 11:52 PM | #14 |
06-13-2017, 12:00 AM | #15 | |
06-13-2017, 12:51 AM | #16 | |
Always on the hunt...
06-13-2017, 12:46 PM | #17 |
Nothing like confirmation, thank you. The top of your rear bracket looks bent like mine. I don't suppose that's on purpose.
06-15-2017, 07:06 PM | #18 |
That rear lifting eye bracket is normally found flat to the rear of pass. side head and usually gets bent when lifting the big block without a load spreader or leveler. Mel
06-16-2017, 06:30 PM | #19 |
Thanks Mel, appreciate it. On a side @ "pre-bent". Couldn't help it. On another side, being I have the brackets, new leveler & hoist, I figure to mount em.
