04-08-2011, 06:02 AM | #176 |
Re: Improve mileage 350 with Quadrajet
do you have a schematic of how the water flow through the engine, radiator and heater core? that would help me a lot.
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
04-08-2011, 07:46 AM | #177 |
78K & 79C Jimmys
post a pic of the engine standing by the wheels
get the rad hoses and block in the pic both sides
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-08-2011, 02:59 PM | #178 |
I already got some more info.
I took the upper radhose of tonight and with cold engine there is no flow. This is good, this means the thermostaat DOES close at low temp. I think the thermostaat opens at the right temperature and dont think this is causing the problem....I now really suspect the Flexfan cooling the engine all the time is the main problem of my engine not getting above 150F.... I am installing a 2400cfm electric fan this weekend and hope this solves my problem of a cold engine....I'll keep in touch....
04-08-2011, 03:01 PM | #179 |
btw heres the pics
passengerside: driverside: its probably hard for you to draw in these pics, because the engine is blokked by hoses for the evaporator of the LPG system that is in my car...(silver round device on driverside) It is parallel connected to the heatercore.
04-11-2011, 03:26 AM | #180 |
after replacing my brakes front and rear completely (calipers, shoes, cilinders and pads) and replacing the vacuum advance. we did some highway driving this weekend. Picked up a princesbed for our doughter about 70miles from here.
We drove for bout 2 x 70 miles about 55-60mph. the engine temp didnt go above 150F again...far too cold I say. we got gas when we got back and the mileage was 1:3,8 in km/l...thats 8,9 mpg here in town and short highway trips we only get about 7,5 mpg...still not very good... the tach showed about 3000rpm all the time...thats probably a big influence in our mileage. I als started to mount a electric fan to replace the Flexfan, hoping this will improve the mileage a little, make the engine bay look better and get the engine temp up...and what do you know...I drove around this morning with the flexfan on, but without the shroud and the engine temp got up to 170F after just a 10 mile roundtrip...tghats 20 more then the 150 we have been getting...I bet when the electric fan is on and the flexfan is of the temp will go up to 190-200 were it should be with a 195F thermostat... i'll be back!
04-12-2011, 05:32 PM | #181 |
got the electric fan setup done and it looks pretty fine.
and finally, my engine gets up to operating temperature. It hadnt gotten above 150F for over a year now! main reason...damn Flexfan! took it off, replaced it with an electric fan and voila..engine heats up nice and quick and when the fan hits 200F, it cools down within 1 or 2 minutes to 185F. only thing left is to attach a LED parellel to the electric fan, so I can see on my dash if the fan is running or not...thanks for the tip Gchemist
04-14-2011, 10:42 AM | #182 |
78K & 79C Jimmys
looks good but i'm not sure if it will cool enough
the shroud funnels the air threw the whole rad that setup may not get enough air threw,some being blocked, some being open with no draw
04-14-2011, 10:47 AM | #183 | |
78K & 79C Jimmys
04-14-2011, 01:21 PM | #184 | |
and when it sits and idles and hit the 200F it is cooled down to 185F in 1-2 minutes..summertime will be the big test...fingers crossed! but it looks good! I can finally see my engine! hahaha
04-14-2011, 02:22 PM | #185 |
The big question is; will you mpg's improve now the engine's getting up to it's proper operating temperature.....
Keep us posted.
1972 GMC 2500 Sierra 350 1971 Pontiac LeMans Sport 400 GTO/Judge Clone 1970 Pontiac GTO 400 convertible restoproject 1970 Pontiac Bonneville 455 convertible Last edited by erikgto; 04-14-2011 at 02:23 PM. |
04-14-2011, 03:01 PM | #186 |
I dont have any hope for that...although it will be better for engine life expentancy!
untill now nothing seems to improve my mileage: - new spark wires (old ones spark against engine) - LPG tune up - changed timing from 0 BTDC to 10 BTDC - Cold Air intake - flex fan in stead of fixed fan - and now electric fan - changed the vacuum advance for a new one - flushed the cooling system - replaced brake calipers and pads front and cilinders and shoes rear (they were rubbing) every time I think, THIS will make a difference....NOT! recently we drove 55 mph for 200 km and our mileage improved from an average of 6 to 7.....big deal! hahahaha....
04-15-2011, 12:32 PM | #187 |
There should be at least a slight improvement since your engine does not have to turn the fan constantly anymore. I don't know if it would enough to notice or not.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter |
04-15-2011, 02:52 PM | #188 | |
MPG will follow soon! i'll be back!
04-18-2011, 04:28 PM | #189 |
Mpg seemed to have improved from 6 to 7 Mpg.
04-21-2011, 05:02 PM | #190 |
hahaha suc6....
I got gas this night for the second time after changing to the electric fan and indeed, theres improvement. My MPG was 7,5 mpg and after the first tank of gas I got 8,23 mpg and 2nite I got gas again and it was up even more to 8,7 mpg finally some improvement. I wonder if it is the warmer engine or the removed flexfan that is causing this improvement... I am happy! :-)
05-01-2011, 02:12 PM | #191 |
I drove some highway miles this weekend. Did about 55-60 mph...
My milage was 9,24... I guess its tw thing causing better milage....warmer engine and less drag of the flexfan...wonder wich makes the most?
05-03-2011, 04:00 PM | #192 |
because I was scared I was cooling my engine through the heater core return connection on my radiator, I moved this connection from the radiator to the waterpump.
Normally the heatercore does not get any water untill you demand heating in the cabin. But in my setup the evaporator for my LPG system is connected in parallel to it. Therefor I was thinking I was circulating water through the passenger side of the radiator and therefor cooling the engine. Because on the highway my engine does net get any hotter then 160F.... Well....moving the connection to the waterpump, didnt change a thing. in front of a traffic light the engine will warm up to 200F easily...but as soon as I start driving the temperaature will go down to about 160F...highway and city... I have absulutely no clue what could be cooling my engine...please help!
05-05-2011, 01:24 PM | #193 |
78K & 79C Jimmys
when i did my heater core in my 88 I remember a valve to stop the flow to the rear tho there was no valve to stop the coolant going threw the core
unless my hook up was wrong Would it be worth it to try with no heater core connected? or put a valve or two in to shut it off?
05-05-2011, 02:22 PM | #194 | |
I am cooking the thermostat 2nite, to see when it opens. I'll upload a video soon...
05-05-2011, 04:21 PM | #195 |
alrighty, tested the thermostat 2nite. I dont have a thermometer, so I used the thermo-cap from my rad to measure the temperature.
at 80C (175F) it starts to open. You can see this in the video at about 55 seconds when the bubble escapes from under the thermostat. at about 2 minutes the thermostat is wide open when the water cooks. when it cools down it is closed again at 80C (so 175F). that is at about 6 minutes into the video. isnt opening up at about 175F to early for a 195F thermostat? this is the youtube video:
05-15-2011, 05:18 PM | #196 |
ever since I cooked and tested the thermostat, the engine seems to warm up a little further and remain warmer on road and highway trips. And this makes me very happy.
I also noticed that my mileage improved even further. the last two times I got gas (LPG in my case) I had a mileage of 9.4 MPG and 8.7 MPG Something else I noticed is that the scale on the temperature gauge on the dash is not lineair: the left side runs from 100 to 210. A difference of 110 degrees. the right side runs from 210 to 260. A difference of only 50 degrees. So who know what the number is for the points in between on the left and right side of the 210F?
05-15-2011, 05:19 PM | #197 |
10-02-2011, 08:54 AM | #198 |
changed my sparkplugs after 12.000 miles and put a clean airfilter in after 6500 miles.
mileage is now at 9.5 mpg
10-02-2011, 11:43 AM | #199 |
What kind of transmission is in your suburban?
10-02-2011, 01:40 PM | #200 |
TH400 with a killing end gear ratio of 1:4.1
My engine makes 3000 rpm when driving 90-100 km/h (about 55-60 mph)
