Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 02-06-2023, 01:21 AM   #1
straight6chevyguy
straight6chevyguy's Avatar
How hard is it to lift a 2002 S10?
Hi guys, just picked up a 2002 Chevy S10 4x4 extended cab 4.3v6 automatic.
Thinking of lifting it. How hard is it to lift one of these?
Not really wanting a crazy high lift, just enough so I can put on some slightly bigger tires and have a little bit more ground clearance.
And if anyone has pictures of there lifted S10 I would love to see them!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1998 chevy c1500 4.3L 5speed (My current driver)
2002 Chevy s10 4.3L auto 4x4
1971 mercury monterey wagon 400 auto
To many projects!
straight6chevyguy is offline   Reply With Quote
Old 03-22-2023, 02:50 PM   #2
OL SKOOL
OL SKOOL's Avatar
Re: How hard is it to lift a 2002 S10?
This is a 1999 s10 zr-2 lifted from the factory. You can buy lifted spindles and lift blocks for the rear will give you 2-2 1/2 inches. I personally would stay away from a body lift. You can also crank tbars up a little in the front don't go wild you won't like the ride. I rebuilt the frontend on this truck previous owner had t bars all the way up rode like an old wagon.
OL SKOOL is offline   Reply With Quote
Old 03-22-2023, 04:44 PM   #3
Accelo
Accelo's Avatar
I used to replace the front CV joints in lifted S10 Trucks and Blazers all the time.
Not trying to sway you in any way. Just be ready for the issues lifting creates.
I think they look good lifted.
Accelo is offline   Reply With Quote
Old 03-30-2023, 01:26 PM   #4
straight6chevyguy
Any opinions on running bigger tires?
Or should I just stick with stock tire sizes?
To many projects!
Old 04-02-2023, 10:13 AM   #5
Hotcorner
Hotcorner's Avatar
There’s some info on this on the Blazerforum. You can go a little bigger with stock wheels and no lift. Wider wheels with more negative offset might help prevent run, but then you’re affecting the scrub angle.
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
