Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-20-2020, 07:19 PM   #1
BC10
BC10's Avatar
Grey Heater Wire
Was looking to make a connection between my amp and the ignition, when I spotted this loose connection. I found out that it is a heater wire. But where exactly does it connect to? I have a 68 C10 with no AC.
Thanks!
BC10 is offline   Reply With Quote
Old 09-21-2020, 01:29 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Grey Heater Wire
Gray wires are usually dash light wires and the heater panel has a light, so check to see if it will plug into the panel to power the light. also if you have a volt meter you can connect between the wire terminal and ground and turn on the lights and check for 12 volts on the terminal. be sure the dimmer knob on the headlight switch is turned on full bright. VV
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-21-2020, 03:10 AM   #3
BC10
BC10's Avatar
Thanks VV
I looked at the back of my heater panel, and all I saw was one connection that is already plugged in.
Is there another spot on the heater panel that has a connection that I am not aware of? I did notice that right behind the lettering on my heater panel there is a housing that has nothing inside of it.
Old 09-21-2020, 08:04 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
There is also a wire for the glove box but not all trucks had a light in the glove box. If it will reach that may be it. try the test with the headlight switch to see if it is powered by the headlight switch.
One of the guys should chime in that has changed the under dash harness with the information you're looking for > I will check my 67 today and see if I can find it.
The heater panel has the switch with the harness plugged into it and the light. I'll check my diagrams and see if I can find any other grey wires like that one.
VetteVet
Old 09-21-2020, 08:41 AM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I forgot that the AC panel has two bulbs so the grey wire may be for the second one . I don't have AC either but I did a search and the power wire for the heater
panel and AC lights plugs into the fuse panel. If your heater panel light is working then you should have that wire and the one in question is probably for the other light.
See the diagram. Check the blue arrows.
Name:  ac diagram 1.jpg
VetteVet
Old 09-21-2020, 03:06 PM   #6
BC10
BC10's Avatar
Yup, the wire is for the heater panel illumination. Thanks so much VV!
Now I have to get a harness, always wondered what that little empty box on the back of the heater panel was for. Lol
Old 09-22-2020, 08:14 AM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Your welcome, I am very pleased to help. Enjoy your truck.
VetteVet
