01-03-2018, 02:11 AM | #1 |
WTB HO-52/72 4.10 gears
Just need good ring and pinion, but will buy whole center section. Also might be interested in rear brake parts. Thanks, Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
01-03-2018, 04:16 PM | #2 |
Re: WTB HO-52/72 4.10 gears
I can help with the brake parts. No pumpkins..
01-04-2018, 09:43 PM | #3 |
Looking for parts for 12x2 with slid on drums for a K20, 64-? What do you have?
01-06-2018, 01:02 AM | #4 |
Ok,
The 4:10 or 4:11 gears are not very common. They are more common in the later years the Easton rear was used, especially behind automatic transmissions. You may want to also ask in 67-72 parts section. Most common on 69 to 72 trucks, but still kind of rare. You might even find a "No-Spin". Hope this helps. |
01-06-2018, 12:52 PM | #5 | |
03-08-2018, 04:06 PM | #6 |
I've got one I'll have to check what it is when I can dig outta snow
1967 GMC fleetside LS 1970 C10 Fleetside LS 5.3 4L60e 1971 C10 Utility LS 4.8 4L60e 1955 L3800 Panel Truck 7469 orig miles |
03-09-2018, 10:48 PM | #7 |
Tom, I have a 64 C20 that I'm converting to 1/2 ton for ride purposes and I"ve got what I believe is an HO72 rear end. I turned it manually and it appears to have 4:10/4:11. I"ll go under and take some pictures of it. I'm in North Orange County and its not too far of a BEAUTIFUL drive down. I'll let you know and post pictures of what I've got tomorrow in the sunlight (rain if forecast but I'm thinking positive). If i have what you're looking for, I'll pass on a good price since someone else on the board set me up on the new rear end, What goes around comes around. Tony
03-10-2018, 03:26 AM | #8 | |
Found a good one locally, so no longer looking. Hopefully you can find it a good home as I know others looking for that ratio. Appreciate the offer, Tom
03-10-2018, 03:30 AM | #9 |
I found one, but thanks anyway, Tom
03-10-2018, 04:46 AM | #10 |
dang, late to this one but I'm not far, actually driving near you to pick up a D60 posi 4:10 to replace my HO52 completely..
mine is leaf sprung and 40.5" spring perch centers.. it will find a good home some day I suppose.. good job finding what you needed!
I started out with nothing - and I still have most of it |
03-10-2018, 05:05 AM | #11 |
I would be interested in a 4.10 center. Post some pics if possible
Thanks |
03-10-2018, 12:18 PM | #12 |
Also interested in a 4.10 -Burbank area
03-13-2018, 08:16 PM | #13 | |
Thanks, Tom
03-14-2018, 12:54 AM | #14 |
^ yep, out of '71 K20 Burb, no idea about brakes, haven't got to inspecting wheel ends yet.. yer welcome to send pm, that axle is coming out complete as soon a D60 is set up, picked it up already
09-08-2018, 06:16 PM | #15 |
Do anyone have a center section that I can buy...I have a 54 3600 that needs a gear change and want to find an HO-52 with the 4.10 gear.
Thanks |
09-08-2018, 06:20 PM | #16 | |
