11-29-2017, 07:22 PM | #1 |
TH350 rebuild
OK' its my turn, I am going to rebuild my tranny and have been shopping for kits. What ya'll think of this kit is there anything else I need? Besides a TC
https://www.ebay.com/itm/TH350-Trans...53.m1438.l2649 |
12-02-2017, 12:05 PM | #2 |
Re: TH350 rebuild
Ttt.
12-02-2017, 08:18 PM | #3 |
Re: TH350 rebuild
Looks OK to me, I would add......
-'87 & up 700R4/4L60E Center Support & Lo Roller Clutch. -Case Saver.....Most TH350's need this because wear at the case lugs. -Wide Direct Drum Bushing. -Internally Dual Feed the Direct Clutches (need a 3/8-24 set-screw & Tap). -If revving over 5,800.....You will need High Rate Direct Piston Return Springs. -Trans Go SK-350 shift kit.....Nice flat Separator Plate, Better Support Plate gasket, Good PR Spring, And some Governor Springs to play with. -File the Support Plate 'til flat. |
