Scottsdale vs Silverado side trim?
Reading these descriptions, it appears the Scottsdale had a black plastic/rubber strip with a chrome upper and lower edge; while the Silverado likely used a chrome strip with two small black paint lines. Is this correct? Is the Scottsdale strip reproduced by anyone?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
![]() ![]() Join Date: Jun 2012
Re: Scottsdale vs Silverado side trim?
Yes, Scottsdale’s came standard with single headlight grilles and black side molding and Silverado’s had dual headlights, chrome molding and wheel well trim. However, you could order a Scottsdale with the bright appearance package and get dual headlights, chrome molding and wheel well trim.
Most of the after market suppliers carry both versions of the molding. https://www.usa1industries.com/1981-...ding-roll.html
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
#3 | |
The inside of this brochure did describe this truck as being a Scottsdale v20, with Canyon Copper upper paint, and Midnight Black lower paint.
According to the info in that page they would have been an added option on the Scottsdale package which I think could be done. Maybe Keith will chime in.
