07-09-2017, 09:20 AM | #1 |
Engine positioning question
Current setup: 1st gen SB 350 & TH400 in a '68 SWB stepper. Swapping in a Vortec 5.3 & 4l60 from a 2005 Silverado.
Question: to avoid driveshaft modification, where should the engine be positioned? Moved forward, back, or original position? Any mount recommendations to achieve this? I am hoping that the two engine/tranny combos are basically the same dimensions so it will be in the same original position so my shifter linkage won't have to be modified. Any advice/recommendations? Thanks! |
07-09-2017, 01:07 PM | #2 |
A guy with a truck
Re: Engine positioning question
Depends on the length of your 400. You will at least need a new yoke for the 60e. If the transmission lengths are identical, 1" setback mounts will put the engine/bellhousing location in the same relative location as your current setup.
Honestly, there are bigger/more expensive things to worry about than driveshaft length. I'd get the drivetrain fitting right and clearing everywhere else, then cut/build a driveline to fit.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
07-09-2017, 01:08 PM | #3 |
I just re-mounted the same engine / trans combo in my 67 yesterday after cleaning up the firewall and frame. I used the CPP sheet metal stands and slider mounts with their trans crossmember. I used the rear position on the frame for the stands and pushed the engine as far back as possible without my headers touching the firewall. i did need to drill 4 holes for the new crossmember as it fell right in between the holes from the original trans crossmember. I was able to use the same driveline but since you'll need to switch yokes (27 spline) make sure you measure and get a yoke length that fits accordingly.
07-09-2017, 01:39 PM | #4 |
Thanks for the info/advise guys, just what I needed!
