10-03-2011, 11:49 PM | #1 |
Convert 3 on tree or truck 4 spd? Need help
I have a 68 chevy c10 with a 327 and 3OTT, can you convert these to floor shifts? if so how? and I have a 4 speed out of a truck i picked up for $50 should I use this instead?
Under Construction....but determined to finish |
10-04-2011, 12:01 AM | #2 |
Grandpa in the rustmobile...
Re: Convert 3 on tree or truck 4 spd? Need help
leave it three speed for the cool factor!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-04-2011, 06:46 AM | #3 |
I bought a 70 last week with the 3ott. Ihad a lot of trouble getting her home because of the 2-3 hangup. The shifter is really sloppy and hard to manage. I have another column[or 2] I could put in for now but my plan is a T-5 overdrive install. I allready have the s-10 trans and the v-8 camaro trans just have to go collect these up. I also have a van tilt that I shaved the shifter bowl and gear pointer on to make it smooth so I can hve a tilt in there when I changr to the floor. To answer your questions yes, you can put a shifter in the floor , they are readily available and not that difficult to install
10-04-2011, 10:14 AM | #4 |
I believe you can adjust it and you can get new bushings. If your interested i'll find you the links
10-04-2011, 10:19 AM | #5 |
BlahBlahBlah
You just need to find an aftermarket floor shifter for that application and install it. It "should" come with everything you need. When you are done, you just toss all the three on the tree stuff.
I wouldnt bother with the truck four speed, but that is a personal preference.
… … … … … … … … ... … … … … … … … … … … … Last edited by CG; 10-04-2011 at 10:25 AM. |
10-04-2011, 01:23 PM | #6 |
10-04-2011, 09:35 PM | #7 |
BlahBlahBlah
Thats a nice link ... good read, thanks
10-04-2011, 10:49 PM | #8 |
Yeah, You could convert or put a truck 4-speed in it..........Or you could go and get a New Process 833 4 speed with an overdrive out of 80-85 Chevy C10. That is what i am doing on mine. just need to buy auto cross member and shorten your shaft. Be sure to get the bell housing with it.
Here's a link about them: http://www.classicjunkyard.com/new_process_a833.htm
Ben Its a 67 Chevy C10 now, and its short now too. Here is my 1967 Chevy C10 Shortened Build Blog http://boyescustoms.blogspot.com Here is my 1967 Chevy C10 Shortened Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=433535 |
11-03-2013, 01:40 AM | #9 |
Been thinking about the 4 on the tree....and found this......
reverse 'knob' would have to go somewhere nifty tho |
11-03-2013, 02:02 AM | #10 | |
hey Jim,
shaving the bowl ....interesting can you give me more info i have 2 original auto truck tilts or should i look to do a trade for a floor shift tilt instead of molesting them what u think jz Quote:
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-03-2013, 11:00 AM | #11 |
What I did was to get a van tilt. I had been picking up a few items here and there after I bought my first truck that I didn't get to work on [much]. Then I found this van tilt it has some problems with the shifter the mech. where the shifter arm went into the arm at the top of the bowl was worn pretty bad and the pin that holds the arm in was wollowed out. So when I bought this 3 speed truck and decided it was to be a 5 speed, that column made perfect sense to me. I took the pin out holding the shifter arm in at the top, this wasn't a problem since it was all jacked up, I just pulled it with a pair of needle nose pliers. then I ground off the knot where the shifter arm had been. I also removed the shifter indicator screws and the lens and pointer, once that was done I welded up the little holes left from the screws. Next I made patches to go inside the bowl where the open areas are that are exposed from the removed parts. I slid the patches into place then placed fiber strand over the holes[fiber strand is a fiber glass based body filler but stronger]. With dry and ground smooth I then did the remaining body work with filler finishing with high build primer. One other thing. To keep the inside shift tube from moving around, I placed the shifter in what would have been the park position and then tacked the inner tube to the outer tube. Now the column is smooth all around it and look just as if it were one fro ma floor shift tilt. Now as far as doing one of yours I wouldn't I would get another instead of cutting an factory truck one knowing what they are going for . You can pick up one on E-Bay[van tilt] for 25% of what your will bring. Good luck if you need anything else holler. Jim
11-03-2013, 11:49 AM | #12 |
Registered Cruiser
I wouldn't get a truck 4-speed unless you plan on pulling stumps. I've got a Saginaw in mine. They bolt right in with no modifications other than the hole in your floorboard. They're quiet, and it shifts real smooth. Hurst has linkage available that you can use with a bench seat.
I intend to live forever. So far, so good. |
11-03-2013, 04:57 PM | #13 | |
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
11-03-2013, 05:31 PM | #14 |
Don't change it man. Get it fixed if it needs fixing but keep it. Not very many of those around.
Mine is a 3 speed on the column and for a long time I wanted to change it too but now, I like it just the way it is. It's definately different and not many thieves know how to drive it. If you want a 4 in the floor....buy one. It's much cheaper in the long run and you don't alter what is a rare bird. Now if you just HAVE to get rid of your 3 on the tree, let me know so that I can get it from you. Just in case mine ever goes out. I'm serious. I'll keep all that for spare parts. |
11-03-2013, 08:21 PM | #15 | |
They are a nice little trans, in low/moderate hp situations. Plus - you can get them with a 3.11 low gear which really helps those low/moderate hp engines get off the line! K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-03-2013, 08:22 PM | #16 | |
K
11-03-2013, 08:54 PM | #17 | |
I really like the "open header switch." |
11-03-2013, 10:22 PM | #18 | |
jz
11-03-2013, 10:42 PM | #19 |
The Saginaw 4spd isn't as weak as so many seem to think. Me and my friends are 4spd junkies (for longer than many here have been in this world) and we feel the Sags ain't so bad. Eddie swears he's had better luck with the Saginaw than the Borg Warner. He's ripped a couple of those and no Saginaws. He presently runs one behind a ZZ3 in his '68. One thing's for sure,you can break'em all,but for what a Sag costs it doesn't hurt so bad. Don't miss a shift on any of them while in it or you'll know what I'm sayin'. I have a collection of about all of them. Sure,the hotter trucks will get the Muncies and I'll use the Saginaws in any 3spd I get.
11-03-2013, 11:48 PM | #20 |
Registered Cruiser
Tim's right. We ran them in a IMCA Modified, and beat the snot out of them. I haven't always had a mellow engine in my truck either. I had one that went over 70k miles after rebuilding without touching it. I don't understand why they have such a dubious rep. I've had good luck. It's when you shock them that they break.
11-04-2013, 12:20 AM | #21 |
I ran a Saginaw for a while behind a 327. No issues. Got it for nothing and just had to put new seals in it and a new input bearing. Still have it sitting here in my garage. I didn't abuse it, and the engine isn't a monster, so it was fine.
However, now that I have the TKO..........its all smiles.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
11-04-2013, 12:22 AM | #22 | |
11-04-2013, 12:38 AM | #23 |
I think the only reason they got a bad rap is because they were used in Vegas. They weren't Vega transmissions,they were overkill in a Vega. It was pure economics,I think,why the Sags were used in Monzas and Vegas. They more the cheaper. Figure GM used their 3spd forever as well as the steering boxes. On the muscle cars they used the while variety and it's more confusing than I care to fathom. But,muscle cars were an upgrade and the extra cost was covered in the price. In a Vega it was just the standard transmission,like about all imports had,a 4spd.
I have seen many a Rock Crusher that pops out of 4th. I have one now. You know what the cause is? There's no detent and when you drive resting your hand on the shifter,as many do,eventually the shift fork gets spread
