11-17-2013, 10:47 AM | #1 |
will powdercoat hold up on 327 spark plug shields
If I get my spark plug shields powdercoated on my 327 with ramhorns would it be too hot there or would the coating hold up? Anyone done this?
11-17-2013, 10:52 AM | #2 |
2WD Jimmy
Re: will powdercoat hold up on 327 spark plug shields
Powdercoat melts at 400. I woould think Jet Hot would be a better choice.
11-17-2013, 03:21 PM | #3 |
Yeah I figured that but thought if they weren't touching the manifold they might be ok.
11-17-2013, 03:50 PM | #4 |
My heat tube on big block is powder coated and it has held up without issue, shield will get no more heat than it does, they should be fine with powder on them
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
11-17-2013, 07:51 PM | #5 |
11-17-2013, 08:24 PM | #6 |
2WD Jimmy
Well... There you go. Learn something new every day.
11-17-2013, 09:28 PM | #7 |
Watch out for your cornhole !
It will be fine. I do a lot of motorcycle exhausts with ceramic and powdercoat the heat shields. It works well and lasts. Mine is probably a much "worse case" situation in that the heat shields screw directly to the headers, with only a thin insulated washer under each screw to isolate the exhaust heat from the shield.
11-17-2013, 11:59 PM | #8 |
be sure post some pics of engine when done.
