10-15-2017, 08:36 AM | #1 |
Before I Drill (Mirror Mounting Question)
I'm about to drill the doors for mirrors on the 72 and I have a question about the locations. My 71 came with the small sport mirrors and I'm going to put them on the 72. I carefully measured the hole location on the 71 and was surprised to find that the driver side mirror is 1 inch further forward than the passenger side. I just need someone to confirm this before I start drilling.
10-15-2017, 08:56 AM | #2 |
Petroleum User
Re: Before I Drill (Mirror Mounting Question)
Yes. My '71 shows exactly what you said. Driver side front hole is 7-1/4", rear holes are 11" from front of door. Passenger side front hole is 8-1/4", rear holes are 12" from front of door. I also did not know this.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
10-15-2017, 09:07 AM | #3 |
there is a posting on here in very great detail, I did make a copy of it if you cant find it drop me a note and I'll go to shop and get it to send info on finding it
10-15-2017, 09:34 AM | #4 |
Thanks. Now all I have to do is drill the holes without chipping up the new paint. Anxiety Time!!
10-15-2017, 09:34 AM | #5 |
Moderator
You are correct. Use a step bit to drill your holes in fresh paint.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
10-15-2017, 12:23 PM | #6 |
Here ya go, mounted mine according to this diagram and am very happy with the results.
10-15-2017, 06:25 PM | #7 |
10-15-2017, 06:28 PM | #8 |
Moderator
Looks great
10-15-2017, 08:02 PM | #9 |
Good work. Did you use a step bit and did any of the paint chip off?
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
10-15-2017, 09:20 PM | #10 |
No paint chipped. I masked off the area and used drills to gradually get the holes sized. The one thing I did do was to run each drill bit in reverse to kinda of burn the new paint away and then, I forward the bits.
10-17-2017, 08:11 PM | #11 | |
awesome tip.. I will have to remember that.. great looking truck
1972 Chevy C10 400sbc 4sp Matthew 4:19 And he saith unto them, Follow me, and I will make you fishers of men. |
05-06-2018, 07:23 PM | #12 |
Never Give Up
05-06-2018, 08:27 PM | #13 |
Scrapper 1
I like my grampa big camper mirrors the guys on motor bikes hate them you hit one of them there like Semi mirrors
05-06-2018, 10:36 PM | #14 |
Never Give Up
Does anyone know what the lines that numbers 20 & 35 refer to, are located from?
05-07-2018, 02:19 AM | #15 |
I just installed the passenger side with the same mirror. Are you able to adjust it in enough to actually see behind the truck? I used that same assembly manual location and I have to move my head over to the passenger side to see behind the truck. Good looking paint btw.
