Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-28-2019, 07:42 PM   #1
72 GMC C1500
72 GMC C1500's Avatar
LED tail light issue
I recently bought and installed some LED tail lights and reverse lights. The brakes light up fine, but with the brakes engaged, when I put the turn signal on, that light goes out, no blinking, just out, the other one stays on. I've installed an led flasher. I checked other posts, but couldn't find any with the same issue. Any ideas? I appreciate the help!
72 GMC C1500 is offline   Reply With Quote
Old 05-28-2019, 08:06 PM   #2
dmjlambert
dmjlambert's Avatar
Re: LED tail light issue
You could try installing load resistors and see if that helps. That is probably the approach I would take, so I could just use a regular flasher module.
Old 05-29-2019, 01:12 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Do the turn signals work with the brakes not engaged?
The turn signal switches are designed to turn off the brake light on the side that
is selected for the turn so that the turn signal can be seen, while leaving the other brake light illuminated. If neither light is on on the right while turning right or if neither light is on while turning left, I would suspect a bad turn signal switch.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-29-2019, 06:55 AM   #4
72 GMC C1500
Thank you both for your quick replies. VetteVet, forgive my ignorance, but is the turn signal switch the same as the flasher that plugs into the fuse box or is there something else I'm missing. This one is new, but I'll order another and give it a try. Seems like culprit. Thanks again!
Old 05-29-2019, 07:26 AM   #5
72 GMC C1500
And to answer your question, they don't blink at all, with or without the brakes on. Thanks
Old 05-29-2019, 10:07 AM   #6
Rickysnickers
If you end up needing a new relay, try these, https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I replaced my brake lights with LEDs and had the fast blink issue. These solved it. Also, if your hazard lights are on a separate circuit, you'll need one of these for the hazard lights as well then.
Old 05-29-2019, 12:05 PM   #7
72 GMC C1500
Thanks for the heads up. This is the same one I have. Maybe I got a faulty one.
Old 06-03-2019, 12:15 PM   #8
72 GMC C1500
Update-I ordered a new flasher and got it installed...no change. Now here's where I feel like a complete idiot. I started the truck up this weekend and gave it a try and the blinkers work! Apparently the truck needs to be running in order for the blinkers to work. Is this typical?
Old 06-03-2019, 02:17 PM   #9
67 Burb
67 Burb's Avatar
The truck does not necessarily need to be running, however the ignition switch has to be in the "ON" position for the turn signals to operate. (The 4-way flashers and the brake lights will work with the ignition switch off.)
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 06-03-2019, 03:34 PM   #10
SunSoaked
SunSoaked's Avatar
I recently discovered the same thing while rewiring my dash. Apparently my flasher doesn't like low voltage. Once the voltage dropped to 11.5 ish, it slowed down then just stopped. Start the engine and she worked fine. I even had the battery tested and it passed the test. So, I just put my battery charger on it when I'm working on it for long periods without it running. Typical? I don't know, but that's the way mine is.
SunSoaked is offline   Reply With Quote
