Old 09-06-2008, 10:16 PM   #1
72-c20
Packrat
72-c20's Avatar
vibration question: 72 k20
'72 k20 w/4"lift
had a couple of vibrations when going over 60 mph.
first would happen once I went over 60 mph,
then when letting off the gas, there was a different vibration until I got down to about 55 mph.
first vibration was taken care of by new tires/wheels, and a new tie rod end/alignment.
second vibration is still there.... just between 55-60 while decelerating.
thoughts?
gone: --'07 Tahoe LTZ 4WD
--'68 Firebird 400 Convertible
gone: --'72 Chevy K20
72-c20 is offline   Reply With Quote
Old 09-06-2008, 10:50 PM   #2
Blue_71
Bloo
Blue_71's Avatar
Re: vibration question: 72 k20
check the splined slip yoke on the front of your driveshaft. your describing my truck almost spot on, i had a vibration from 45-50, then over 60... found 3 bent wheels. also had a vibration on deceleration from 65 down to 50 so i took the driveshaft to a driveline shop.. he inspected it and found the slip yoke to be worn VERY bad... he said that was causing it, but i cant gaurentee it because i have yet to have it fixed... the guy told me it would cost about $200 for both sides of the slip yoke, and welding and balancing the shaft.
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 09-22-2008, 07:46 AM   #3
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
U-Joints ok?
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 01-06-2011, 12:24 PM   #4
72-c20
Packrat
72-c20's Avatar
well, it's over 2 years later, and I finally got a new driveshaft
the splines on the slip were worn as predicted. it finally started to get worse..
new shaft has lifetime spicer u-joints ( 1350 ) and the tube is slightly smaller diameter with greater wall thickness. the same tubes they use for the pulling trucks...
Old 01-06-2011, 10:47 PM   #5
jakeblues652
jakeblues652's Avatar
new shaft has lifetime spicer u-joints ( 1350 ) and slightly smaller diameter with greater wall thickness. the same tubes they use for the pulling trucks...
sounds like a good excuse for either a big boom, or alot of tire spinning when you're pulling someone from the ditch
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 01-07-2011, 12:25 PM   #6
I bet it feels better at all speeds. She's tight now!
Old 01-08-2011, 05:07 AM   #7
72-c20
Packrat
72-c20's Avatar
