Old 11-05-2018, 03:39 PM   #1
Rdwagoner
67 C10 Throttle cable
Hey all, trying to figure my best options for a throttle cable. I did a 5.3 swap into my 67c10. Had the factory Inline 250 with rod linkage removed. Any ideas for throttle cables? Trying to stay on budget. I also have factory pedal. Will be hooking up to a Summit 600 carburetor. Do I need a new pedal as well? Thanks in advance!
Rdwagoner is offline   Reply With Quote
Old 11-09-2018, 12:41 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 67 C10 Throttle cable
You can use the cable setup from a 1972 Chevy or GMC truck. Pedal assembly will fit and the cable can be adapted to any carb.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
