02-05-2018, 01:16 PM | #1 |
DIY4X crossmember fitment
Alright, here's my dilemma. I'm in the parts gathering phase of converting my 1970 C30 to a K. I have a 1988 V30 donor truck that I'm going to use the axles, trans and transfer case out of. Anyway my question is about the DIY4X first gen cross member.. its height in particular.
My x member 'C' pieces are too tall to fit inside the frame 'C'. Not much, but enough to matter. maybe .125". Has anyone encountered this issue? I put a caliper on Kerts 'C' part and came up with 5.25" tall. Can I persuade one of you gents with a k10/20 frame to measure inside the channel at the x member area? I assume (famous last words) that the frame would have the same height dimensions from the cab forward regardless of 10/20/30 series. Now this issue may be because I have a 1ton frame?? but I find it odd that my frame would be SHORTER than a 1/2 or 3/4 ton. I called DIY4X this morning but Kert was out with the flu. Any help would be appreciated. Thanks,
Dan 1970 C30- 350/SM465 133" WB, Soon to be a K series 1970 C10- LWB 250/3OTT, (sold) 1966 IH Scout 800- 152/T-90/Dana 20/ D27s |
02-05-2018, 01:35 PM | #2 |
Re: DIY4X crossmember fitment
Are you talking about the motor cross member or the trans/transfer case cross member?
02-05-2018, 01:37 PM | #3 |
Engine cross member. Should have been more specific.
02-05-2018, 01:44 PM | #4 |
I have a 72 K10 in the shop. I'll go measure it.
02-05-2018, 01:59 PM | #5 |
On the front side of the cross member this is what I got. Drivers side is right at 5 in. Passenger side is at 5 1/8. My cross member is at the v-8 location so the measurements were taken between the v8 location and the 6 cylinder location.
02-05-2018, 02:05 PM | #6 |
I think the C30 frame height from top to bottom may be greater than the 20. Ignore this, just re-read what you posted. Based on JC's measurements your x member is too tall for his frame also?
02-05-2018, 02:14 PM | #7 | |
Jfc just confirmed my suspicion, it looks like all 1/2, 3/4, and 1ton frames are going to be the same from the firewall/bell housing area forward. Its beginning to look like Kert sent me a faulty piece that was fabbed too tall. I have read nothing but rave reviews about this product, and ultimately decided to go with it over the ORD equivalent. I will contact Kert and work on a resolution. BTW thanks JFC for your help!
02-05-2018, 02:21 PM | #8 | |
02-05-2018, 02:21 PM | #9 |
Correct. My DIY4x piece is measuring 5.21"-5.25" tall. So basically its roughly 1/8" to 1/4" to tall. I believe I read elsewhere on this site that someone got the same part and it was way too short, and had to use shims to make it fit snug.
02-05-2018, 10:49 PM | #10 |
Just something to try if you haven't already is bolt together leave loose install then tighten. If that's a possibility my factory cross member was plenty tight and that's how I got it to work.
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
02-05-2018, 11:05 PM | #11 |
give kirt a call at diy4x
he is super cool to deal with and will help you out . i have lots of his stuff .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
02-05-2018, 11:28 PM | #12 |
That is impossible with the issue I have. the cross member is designed differently than stock and will not even begin to fit in the frame.
02-05-2018, 11:32 PM | #13 |
Bummer. Are you going to start a build thread when you tear into the conversion. Looks like a sweet truck if that's the one in your avatar. Look forward to seeing more.
02-05-2018, 11:35 PM | #14 |
A visual. The inner 'C' part is 1/4" too tall to fit inside my frame 'C'
02-05-2018, 11:37 PM | #15 |
K makes sense now after seeing it put together.
02-05-2018, 11:40 PM | #16 |
Yep. I will start a build thread here once I really dig in. I pulled the engine Saturday and its ready for the 2wd junk to be ripped out. It is the truck in my Avatar, I will upload some better pictures soon. BTW Blue Bullet I'm watching your build closely as it is similar to what I have in mind for my build.
02-05-2018, 11:43 PM | #17 |
Cool sounds like you have the same donor as mine also. Don't hesitate to ask questions if there is something I should be pointing or explaining what I didn't.
02-05-2018, 11:45 PM | #18 |
Blue, while we are on the subject, I have a question! Did your 4x4 cross member line up with any 2wd motor mount holes in your frame? Or did you have to drill new? In my case, the aftermarket x member doesn't appear to line up with any existing holes..
02-05-2018, 11:55 PM | #19 |
I welded everything shut. Then put drivetrain in and cab on. I could see roughly were the front hole was so I started close to that then dialed it in from there. The first test run I had original shifter but V30 linkage. I didn't like that position because I wanted to use the original pipe to radiator and 4x4 shroud. That's when it dawned on me about the linkage. Once I got it positioned according to original high hump hole and original shifter with linkage that's where I was happy with location. I think I could still go big block and have good clearance. If you need some measurements let me know.
02-06-2018, 07:29 AM | #20 |
Answered already but I did the 4wd swap thing to an 89 crew cab. I had access to a junkyard with 1/2, 3/4, and 1 ton 4wd trucks. The engine crossmember is the same
Between them. Maybe by 1/4”....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
02-06-2018, 12:08 PM | #21 |
I just spoke with Kert @ DIY4X and let him know my issue. He measured some of his in stock parts and he says they are correct. The height is supposed to be just shy of 5.25"..
02-06-2018, 01:00 PM | #22 |
What are you going to do?
02-06-2018, 02:30 PM | #23 |
SWB 4x4 Collector
I think what is throwing things off is the thickness of the frame rails themselves. A c30 frame had thicker material for rails than a 1/2 or 3/4 ton. I might be just enough to cause issues. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
02-06-2018, 03:03 PM | #24 |
Hmmm.. That's a good point. I will pull a thickness measurement on my frame rail ASAP. The only thing that has me confused is JFCs measurements on this K10 frame (which is what the cross member is designed for and advertised to fit). His measurements are the same as mine on the C30.
02-06-2018, 04:03 PM | #25 |
SWB 4x4 Collector
I will also measure my 157" Cab and Chassis C30 frame rails. That way we have a definite answer. I think we need to measure all the same way, in between the frame rails. Just so we are all the same. Trevor
