Old 07-04-2018, 10:11 AM   #1
jgarrett354
69 C10 Wheel Change
I have a stock 69 c10. I was trying to put a set of Denali wheels that I took off of my wife's car on it. Can anyone help me figure out what I need to change on the truck to make this work? The wheel wont go over the hub and the studs aren't long enough. Any help would be appreciated.
jgarrett354 is offline   Reply With Quote
Old 07-04-2018, 10:23 AM   #2
Rich69shortfleet
Re: 69 C10 Wheel Change
Well, the first question is: are the bolt pattern sizes even the same? If so, you'd have to have the back of the wheels where the hub fits machined larger (assuming there is enough wheel material there to allow doing this without compromising the strength of the wheel) and put in longer studs. This is also assuming the offset of the wheels is close enough to allow the wheel/tire to fit on the truck without rubbing.
Rich69shortfleet is offline   Reply With Quote
Old 07-04-2018, 01:00 PM   #3
OARNGESI
OARNGESI's Avatar
Just buy adaptors around $100 on eBay. They bolt to your hub then the wheel bolts to them
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
