Old 02-11-2018, 08:41 PM   #1
Tonner
Transmission ID
This is a 3-speed automatic that I pulled out of my '72 C20. I assumed it was a TH350, but the guy at NAPA said that truck with a 350 V8 could have 8 possible transmissions. Where do I scrape to find markings? Can you ID it just by pan shape?
Thanks.
https://drive.google.com/file/d/1tOC...ew?usp=sharing
https://drive.google.com/file/d/1-8f...ew?usp=sharing
https://drive.google.com/file/d/1CC2...ew?usp=sharing
Tonner is offline   Reply With Quote
Old 02-11-2018, 08:48 PM   #2
harpo231
harpo231's Avatar
Re: Transmission ID
http://67-72chevytrucks.com/vboard/a...1&d=1518396470
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 02-11-2018, 08:50 PM   #3
B. W.
B. W.'s Avatar
Re: Transmission ID
turbo 350
B. W. is offline   Reply With Quote
Old 02-11-2018, 11:11 PM   #4
Tonner
Re: Transmission ID
Awesome, thanks!
Old 02-12-2018, 09:10 AM   #5
jocko
jocko's Avatar
Re: Transmission ID
Yes TH350 and I’d stand in line at NAPA at someone else’s register. There were only 2 three-speed automatic transmissions available. 350 and 400.
Old 02-12-2018, 10:37 AM   #6
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Re: Transmission ID
And if you have one as pictured with the Monster label on it you are likely in deep poo poo. Search "Monster complaints" to read the nightmares.
CaptRMW is offline   Reply With Quote
Old 02-12-2018, 11:54 AM   #7
Tonner
Re: Transmission ID
Good to know. It's original, so I think I'm ok.
Old 02-13-2018, 03:03 PM   #8
71gmcC15
71gmcC15's Avatar
Re: Transmission ID
not to hijack this thread but i have a 4 speed manual with a 307 . any ideas what that is because every one just calls it a 4 speed.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 02-13-2018, 03:18 PM   #9
harpo231
harpo231's Avatar
Re: Transmission ID
It's either Muncie or New process [rare]
Stan
67 swb BLU MULE
Old 02-13-2018, 06:17 PM   #10
71gmcC15
71gmcC15's Avatar
Re: Transmission ID
Ok safe bet to say Munice. Nothing specal about my pickup. But is thare an esay way to tell wich one it is that doesn't involve scraping 47 years worth of greas off it. Like is the pan differnt?
Old 02-13-2018, 06:56 PM   #11
harpo231
harpo231's Avatar
Re: Transmission ID
http://67-72chevytrucks.com/vboard/a...18562471562471
new process top
Stan
67 swb BLU MULE
Old 02-13-2018, 09:27 PM   #12
jocko
jocko's Avatar
Re: Transmission ID
Here's a good thread to ID the SM465. This is different from a car trans - has a granny low/1st. http://67-72chevytrucks.com/vboard/s...d.php?t=457810
If original, it should be on the SPID - as "M20" I believe - it was not standard equipment, lack of mention on the SPID would mean the truck was born as a 3-speed.
Old 02-13-2018, 10:20 PM   #13
71gmcC15
71gmcC15's Avatar
Re: Transmission ID
Thanks. Is it differnt for gmcs as standard equipment becuse my spid doent menchin it but it looks factory. Has the correct trans tunnal ,steering colum,and the cluch pedal also looks original.
Old 02-13-2018, 10:32 PM   #14
jocko
jocko's Avatar
Re: Transmission ID
4-speed should be listed on the SPID for Chev or GMC as it was an optional trans. Here's a couple GMC SPIDs for ref. These truck are so old that something swapped in 20 years after it was new can look original at this point, ha. But you never know, SPIDs have had mistakes before!
Old 02-13-2018, 10:54 PM   #15
71gmcC15
71gmcC15's Avatar
Re: Transmission ID
Who knows for sure maby it was swapped in from another 67-72gm truck. That would explane all the correct parts.
