Old 04-16-2018, 10:37 AM   #1
Free Candy Inside
Brake pedal return spring?
I recently did a 73-87 front K swap into a 65 c10. I made a mount for the power brake booster (purchased new). I had a piece machined for an adaptor to use a stock booster that then allows the stock brake pedal adjuster to thread on. The brakes work great but the pedal will not return after pressing them, leaving the brakes dragging. Iím using all the stock 65 pedal assembly.
For anyone who has done a similar swap did you have to add a return spring to the pedal? Seems simple enough but wanted to see what majority did and make sure Iím not missing anything/have another issue.
Thanks in advance!
Free Candy Inside is offline   Reply With Quote
Old 04-16-2018, 11:28 AM   #2
rvrfoot
Re: Brake pedal return spring?
Did you check to make sure nothing is on a bind?
rvrfoot is offline   Reply With Quote
Old 04-16-2018, 11:34 AM   #3
Free Candy Inside
Everything works well except the pedal does not return. Use your foot to bring it back and everything is good.
Old 04-16-2018, 12:12 PM   #4
gizmoduck81
Junior Member
gizmoduck81's Avatar
When this happened to me it was because I over-tightened the booster rod at the pedal. I loosened it up a little and the pedal returned with no issues.
gizmoduck81 is offline   Reply With Quote
Old 04-16-2018, 08:32 PM   #5
racecougar
racecougar's Avatar
Is the stock return spring not in place?
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 04-16-2018, 09:02 PM   #6
The Rocknrod
Too Cool For School
The Rocknrod's Avatar
Here is the brake pedal bracket all assembled including the brake booster, your's should look similar including the spring.
Master Chief, US Navy, Retired - He ain't no drag Papa's got a brand new bag
1964 C10 Step-side Short Bed - In Progress
2009 2500HD Duramax LTZ
1948 GMC Panel
1956 Big Window Stepside
1953 5 Window Chevy Stepside
New Seat Foam for Bench Seats?
The Rocknrod is online now   Reply With Quote
Old 04-16-2018, 10:30 PM   #7
fredhlynch2
Rockenrod,
Love the photo of the booster assembly. Clarifies a few things for me. Did you drill the brake pedal clevis one inch lower on the pedal or is the brake rod still in the original position/hole?
fredhlynch2 is offline   Reply With Quote
Old 04-16-2018, 10:56 PM   #8
The Rocknrod
Too Cool For School
Yes it's drilled lower.
1948 GMC Panel
Old 04-17-2018, 08:11 AM   #9
Free Candy Inside
Old 04-17-2018, 08:13 AM   #10
Free Candy Inside
I may have done the same. Iíll check that when I get home. Be an easy fix if thatís all it was!
Old 04-19-2018, 08:13 AM   #11
Free Candy Inside
For the win! I loosed the bolt slightly and now it works properly. Easy enough fix. Thanks for the help. Guess I just assumed it needed to be tight being a brake part. Lol
Old 04-19-2018, 09:17 AM   #12
rvrfoot
Yep, Like i said something was in a BIND.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
