Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 07-18-2017, 10:15 PM   #1
Trans trouble? Need insight
I have a 91 chevy 2wd it has a 700r4. It seams to be hanging in second. It doesn't want to **** until it hits high rpm. Just don't know much about trans ddint know if it's a stuck valve or what drives great just ain't shifting right any insight will help ty
Wtmiller is offline   Reply With Quote
Old 07-24-2017, 06:19 PM   #2
Alignman88's Avatar
Re: Trans trouble? Need insight
Your TV cable probably just needs adjusted. Drivers side at throttle linkage. Hold throttle at wide open position, then press in the "reset". Push it back toward the bracket and release the reset. This can cause long, drawn out shifts as well as short shifts. A good transmission shop would help if asked, my transmission guy is particular on how he sets them. Here is a quick video overview. Common issue.
Good luck, should be easy.
1988 1500 SWB
1929 Model A Roadster
1960 Biscayne
2016 GMC Denali crew cab Duramax
Alignman88 is offline   Reply With Quote
Old 07-25-2017, 08:10 PM   #3
mountie's Avatar
From what you are saying..... it stays in 2nd until you hit a high rpm? Then a hard shift...... >>>>>>>> If you lay off the accelerator, does it sort of idle?
I had my truck stuck in 2nd.... It was the governor. ( It has a plastic spline gear on one end, that can strip..... The other end has weights that spin)
Believe it or not, not hard to replace.... I have a spare in my truck, but haven't needed it since the tranny was built ( and I mean, BUILT, 18 years ago by Art Carr's shop in Huntington Beach, Ca.)
Now, if your shifting points are way off, then, yea, it could be your "TV cable" ( Throttle Valve cable)..... THIS IS VERY IMPORTANT....
That cable determines the fluid pressure. If pressure is low, you could be driving at 70 mph, but the fluid pressure is for 30mph.. It will burn up your transmission!!
The TV cable, adjusted correctly, .. At a green light, you should be shifting into 2nd gear BY THE MIDDLE of the intersection.
Approximately..... like that.
'70 GTO Midnight Blue
'88 GMC Sierra SLE Camper Pkg 392,000 & still going!
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'96 Honda 550 - Beautifully original
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
mountie is offline   Reply With Quote
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Copyright 1997-2013
