Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 07-29-2017, 10:37 AM   #1
DeanJ
Air conditioning ? Suburban
Ok guys, I recently purchased a 1996 Suburban 2500, 7.4. Has anyone here replaced the AC lines that goes to the rear unit ? The small line is seized to the fitting that goes to the rear evap core. Or does know what fittings to order to replace the alum front to rear hose with rubber AC barrier hose ?
DeanJ is offline   Reply With Quote
Old 08-03-2017, 01:59 PM   #2
87Skier
87Skier's Avatar
Re: Air conditioning ? Suburban
I can't help you much here, but I would think it would be easier to get lines from the junkyard.
The rear evap units are hard to access. Most people cut an access hole in the plastic covering.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 08-04-2017, 08:37 AM   #3
DeanJ
After I got in there, the PO had already cut the evap housing. Had duct taped it back together. I got a piece of the line at the junk yard, and am going to use a line splice. This A/C job has been a tough one. Lol
Old 08-06-2017, 10:30 PM   #4
diveplane
ok i did ac work on my chevy 1500 1994 w/t V6
new ac lines condenser and accumulator .
ok lines going into fire wall u have to be very very very careful breaking the threads, use penetrating oil for a few nights before even trying to break them loose. u screw the threads on these u are in big do do, as u would need to rip out the dash loose to replace evap core those are buried deep in under dash and firewall.
for the suburban it may be the same lines as mine but it's best to check autozone.
great having ac again..
diveplane is offline   Reply With Quote
Old 08-06-2017, 10:32 PM   #5
diveplane
for ac best to buy new parts.
Old 08-07-2017, 08:11 PM   #6
Kudzupatch
Kudzupatch's Avatar
Would love to know more about how you made the shroud.
Kudzupatch is online now   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
