07-07-2017, 12:24 AM | #1 |
I-6 power steering pump bracket?
Is the power steering pump bracket specific to the I-6?
I have the whole PS system but the pump bracket is from a Small Block. If it is specific, is there a vendor that sells them? If not, would a bracket from a later year (square body) work? I've never seen a 67-72 I-6 truck with PS in the yard, but have on the later models |
07-07-2017, 12:49 AM | #2 |
Re: I-6 power steering pump bracket?
The L6s had different P/S brackets, one for the 250 and another for the 292. They were both totally different from the SBC brackets. I don't know if big block V8s had different brackets from small blocks. Probably so.
P/S brackets for the 250 can be found with a little digging. 292s were a different story. Quite rare, as most 292s were in work trucks, fleet trucks, school busses, UPS vans, etc. and were not ordered with any extras. I've seen 292 P/S and AC brackets on ebay, but aftermarket stuff, and expensive. Pix showing a 250 P/S Pump and bracket not quite fitting a 292 L6.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-07-2017 at 01:01 AM. |
07-07-2017, 09:14 AM | #3 |
Just FYI, the later I6 with integral-manifold-head brackets are different than the early ones that have a separate manifold. They can be modified, but it is best to find like for like. Novas seem to be a good source for this bracket for some reason.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
07-07-2017, 09:57 AM | #4 |
Well, it sounds like I'll be on the hunt for a Leprechaun, riding a Unicorn.
Wish me luck. Oh, and thanks for all the info |
07-07-2017, 03:12 PM | #5 |
That's only Leprechauns with Red vests on Roan unicorns.
07-07-2017, 03:17 PM | #6 |
Do you have a 250 or a 292? Here is a pump with 292 bracket on eBay. https://www.ebay.com/itm/232022190254
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
