Old 10-05-2009, 10:50 PM   #1
chicklin
chicklin's Avatar
Remove 6" lift kit
Hey, I'm looking at a 1979 3/4 ton Suburban that has a 6" lift kit on it. I was wondering how big of a pain it would be to remove the lift. I'm guessing I'd need to get four factory shocks. Other than that, are there any gotchas? I would think the brake lines may end up too long, but that's not too big a deal and could be fixed later. What do you think?
chicklin is offline   Reply With Quote
Old 10-06-2009, 08:34 AM   #2
Jonboy
Slots go on anything!
Re: Remove 6" lift kit
If it was done right, you will need to replace the front springs, shocks, steering arm, and drag link. You will want to make sure the transfer case was not dropped, and you will need new rear U-bolts if blocks were used. I don't think the brake lines will be too big of a problem, just make sure they are routed out of the way. I would try to see if you could find someone with a stock truck that would like to trade for your lift, and swap it all over.
Jonboy is offline   Reply With Quote
Old 10-06-2009, 10:52 PM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
With 6" the drive shafts might of been lengthened...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
