Old 07-01-2018, 11:31 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Timing chain, is this on purpose or a fluke?
71 402 block stock
I had a bit of trouble lining up the chain, nothing major. First time I thought it was right I noticed the slack was uneven between gears. Couldn't tell you, probably a link off. Somehow the bolts lined up anyway. "Damn my eyes", I probably missed something obvious. At least I saw it was wrong.
Second time I noticed how one link is clear instead of gray. Thought huh, I'll match it up to the timing tooth, see what happens. Dead-on, went right on and the slack is even. That a fluke or on purpose? Course there were no instructions. Might be a good thing (YIKES), instructions these days, what a disaster.
On the side;
Not sure how you guys KNOW the sprocket marks are lined up perfectly. Best I can tell is employ the eye test. Level is happy, but I don't put much stock in a torpedo level for this purpose. In other words, there's a little slop when you turn the crank & cam individually. What might be plumb to one guy may differ the next. Close is good enough maybe, can't really say.
I baked the crank sprocket with butter It went on, though not quite all the way. So I tapped it a pinch with a hammer and thought nope, didn't wanna. Not sure cooking a sprocket is a wise idea anyway, so I tossed it. Second time I used a crank sprocket tool with a harmonic balancer install kit, and high pressure (i.e., anti-seize) lube. Went on like butter.
Bought new crank bolts from ARP. Their instructions say torque @ 25 ft. lbs. and use "ARP anti-seize lube". Thought that was odd. From what I've read you should use blue lock-tite (the opposite), though torque at 20 ft. lbs. Unless someone suggests otherwise, think I'll run with the latter.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-02-2018, 09:04 AM   #2
Mike C
Mike C's Avatar
Re: Timing chain, is this on purpose or a fluke?
ARP’s lubricant gives much more accurate torque readings than doing it dry or with Locktite. They probably expect you to use a cam bolt lock plate instead of liquid locking fluid or lock washes. That is also what I would recommend purchasing.
Not sure about your chain alignment, it looks OK to me? I never run link belt chains anymore. Rollers are just too inexpensive and seem to be better suited to long term use.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Mike C is online now   Reply With Quote
Old 07-02-2018, 10:49 PM   #3
71CHEVYSHORTBED402
I believe you, so I ordered a locking plate and even ARP's "special" lube.
I double checked the sprockets with a straight edge. They're money, 08.25" from the same portion of the block to the front edge of the teeth.
This is all new to me, and never thought about a roller chain. Summit recommended a double chain or something like, but didn't want to concern myself with clearance, and if a standard chain was good enough for Mickey (rebuild) it's good enough for me. Then again, I replaced his chain, probably stretched to some extent (40K miles).
Thanks a bunch for the info.
Tony
