Old 03-09-2017, 09:16 PM   #51
doc74021
Re: 1969 Chevy short stepside
Getting everything put back together. Started welding in the inner cowl.
doc74021 is offline   Reply With Quote
Old 03-09-2017, 09:20 PM   #52
doc74021
Started my sheet metal work on cleaning up the firewall.
Old 03-10-2017, 10:43 PM   #53
doc74021
Worked more on the firewall.
Old 03-11-2017, 07:43 PM   #54
Rod Run
Rod Run's Avatar
That top filler panel is real fun, huh? LOL
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 03-11-2017, 08:38 PM   #55
doc74021
Oh yeah lol. It makes it look so good but it is SO much work for such a little amount.
Old 03-11-2017, 08:47 PM   #56
Rod Run
Rod Run's Avatar
I loved it after I did mine, but you are right
Old 03-11-2017, 09:07 PM   #57
doc74021
Figured I would take a break from the firewall and fill up the gas filler neck hole. It took longer to make my circle than to weld it in.
Old 03-11-2017, 09:09 PM   #58
doc74021
Couple more pics.
Old 03-11-2017, 09:12 PM   #59
doc74021
I started stripping down the door and whoever did the body work was not very bright. I found up to 1/2" of body filler in places.
Old 03-11-2017, 09:14 PM   #60
doc74021
Did you leave the area by the blower motor hole or did you make it look like the other side?
Old 03-12-2017, 06:40 PM   #61
doc74021
These are the wheels I plan to use. They are 20x8 for the front and 20x9.5 on the back.
Old 12-24-2017, 10:52 PM   #62
doc74021
Haven't posted in quite awhile. The floor was pretty rusted out.
Old 12-24-2017, 10:57 PM   #63
doc74021
I went ahead and filled in the hole for the blower motor and fabed up a piece to complete the firewall.
Old 12-24-2017, 10:59 PM   #64
doc74021
I decided I’m going to shave the drip rail. It is pretty rusted under there.
Old 01-13-2018, 08:30 PM   #65
doc74021
I started stripping all the paint off the back. I did find some quarter size dents that I will pull.
Old 01-13-2018, 08:32 PM   #66
doc74021
This is where I started shaving the drip rails. I welded up the side part.
Old 01-13-2018, 08:36 PM   #67
doc74021
The first pic is where I started flattening out the firewall. The second pic is where I shaved off the cowl piece to make it look a little better. The third pic is just progress of the cab.
Old 01-14-2018, 06:58 PM   #68
Rod Run
Rod Run's Avatar
Lot of work, but that stuff always looks good when it's all finished up
Old 01-14-2018, 08:11 PM   #69
doc74021
Rod run, you are not kidding it is a ton of work.
Old 01-14-2018, 09:02 PM   #70
Rod Run
Rod Run's Avatar
I know all to well
Old 01-14-2018, 09:04 PM   #71
Rod Run
Rod Run's Avatar
This is my Project TLOW
Old 01-14-2018, 09:20 PM   #72
doc74021
Very nice.
Old 02-18-2018, 11:34 AM   #73
RCbowtie69
RCbowtie69's Avatar
Looking great on your build,keep the progress going forward & keep on truckin'
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
