Old 06-13-2019, 10:47 PM   #1
duramax55
break question
hi i am doing my brakes and was wondering if a residual valve is needed . Itwill have fire wall hydraulic booster from a 2005 2500 truck i am using the platform from the same truck, only thing that has changed is i took out the abs out of it
duramax55 is offline   Reply With Quote
Old 06-13-2019, 11:10 PM   #2
mr48chev
mr48chev's Avatar
Re: break question
I'm thinking that the master cylinder that you are probably using won't have any sort of residual check valves as in the original application it would have depended on the combination valve for that.
My ongoing truck projects:
