Old 09-13-2018, 10:45 PM   #1
MAGGEE
Media Blasting Advice
I am having my truckís bed media blasted in preparation for some new paint. Should I disassemble the bed for blasting or just blast it assembled ? Disassembly will take more time (and/or money). Not sure itís worth it. Iím not doing a full restoration. Iíve just replaced my old, very rusty bed with an old, nearly rust free one. The bedís in great shape, but itís brown- and my truck is not. Any thoughts?
MAGGEE is offline   Reply With Quote
Old 09-13-2018, 11:04 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Media Blasting Advice
Post a picture of the bed you want to have blasted , Some commercial blasting companies will blast your parts at 175 psi + ,While that's fine for a frame it can warp and distort sheet metal .
Old 09-13-2018, 11:05 PM   #3
projectking
projectking's Avatar
Yes, I would recommend blasting and 2 coats of epoxy too all mating surfaces.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is online now   Reply With Quote
Old 09-14-2018, 12:45 AM   #4
CUDA8U
CUDA8U's Avatar
blow it apart,blast it all,epoxy prime,paint the floor and box inside and reassemble
The seams are prob loaded with dirt and rust and need to be cleaned up or it will come back to haunt you.
CUDA8U is offline   Reply With Quote
Old 09-14-2018, 07:04 AM   #5
clay68c10
clay68c10's Avatar
Take it apart, this is a job you only want to do once. Any rust hiding in the seams will come thru at some point.
It’s a fairly simple job. Just a couple of welds near the tailgate trunions and (seems like) about 5000 bolts. Tighten the carriage bolts to break them off, much easier that way. You’ll want to replace them anyway.
68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17.
68 Cadillac Sedan de Ville
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
02 E320
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-14-2018, 08:22 AM   #6
sick472
sick472's Avatar
Grumpy makes a very good point about potential warping! Make sure your blasterman has a high confidence level in his equipment and ability...you don't want to spend an eternity putty sanding to overcome warpage. And even some of that can't be easily restored if it warps out. My guy refused to hit the long wide areas of my truck (bed sides, hood, and cab top) for that point alone, but sanding or paint stripping those areas is pretty easy. It's the tight spots and along strong body contours and folds in the steel that can take the stronger blasting and that's where the time savings come in compared to using a small bucket blaster and/or sand paper.
I think the dry ice, soda, and walnut shell blasting is less likely to warp, but discuss that with your blasterman, don't take my word for it.
He who is without oil shall throw the first rod. Compressions 8.7:1
sick472 is offline   Reply With Quote
Old 09-14-2018, 12:26 PM   #7
mike16
dry ice media blasting has become the newest fad. it workes very well because it leaves no media behind to clean up later nor does it make a bigger more unmanagable mess.
mike16 is offline   Reply With Quote
Old 09-14-2018, 01:12 PM   #8
Grumpy old man
Does the truck still look like this ? if so you have way more important things to deal with than whether your paint matches and blasting your new rust free bed . Does it still need cab roof rust repair ? rear springs ? Pick your battles wisely and get a real plan and budget together before you find yourself with a blown apart project with no direction .
Frame/suspension /brakes/mechanics/electrical/body/interior/glass/wheels .
Old 09-14-2018, 11:46 PM   #9
MAGGEE
Grumpy Old Man:
The truck still looks similar to those photos. But it’s definitely not still the same truck. Taking some advice from this site, I spent the first several months with the truck working to get it mechanically sound. Lots of new parts any many hours invested between the frame and the ground. Not much required under the hood.’
Frame is solid and straight. Had some surface rust but it’s gone now. New suspension, brakes and lines. Could probably do with a new booster and master at some point. But it stops like it should. No electrical issues. It’s sporting some Craigslist wheels and tires.
After all that was sorted out, I started getting rid of rust. I guess that’s the stage I’m in now. The cab is almost rust free. New floor, corners, etc. Have some new doors on order.
But, I don’t want the project to stall. So, the bed is getting some attention.
Old 09-14-2018, 11:56 PM   #10
MAGGEE
Hereís where itís at now:
Old 09-15-2018, 01:03 AM   #11
57taskforce
57taskforce's Avatar
Nice K10 I would blast the bed and epoxy it like was mentioned above. You’ve made some excellent progress on it! It’s nice to see another 4x4 truck saved!
'57 3100 350/700r4 35x12.5's
'72 K/20 Cheyenne 350/SM465 in pieces awaiting ly6 6.0 swap. http://67-72chevytrucks.com/vboard/s...d.php?t=662879
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6"RCD 315/75/16's
Ď10 Camaro 2SS/RS l99 6l80e 52,000 miles Aqua Blue Metallic.
Old 09-15-2018, 08:48 AM   #12
MAGGEE
Thanks for all the responses. Sounds like the bed will be coming apart for blasting and primer. I think it also makes a lot of sense to paint (at a minimum) all the seams before it goes back together. Otherwise it will just have to come apart again.
Old 09-15-2018, 09:24 AM   #13
Nicks33
Hey Maggee, have you looked at dustless blasting?? I have a 71 k10 project that I'm ready to get started on the bed, it uses high pressure water and glass bead, no warping. They are Mobil and come to you, that's the beauty of it.
Nicks33 is offline   Reply With Quote
Old 09-15-2018, 11:10 AM   #14
MAGGEE
I’ve watched some videos. It’s an interesting option. But there’s not one close. And probably not right for this project.
Old 09-15-2018, 05:04 PM   #15
mike16
sage advice.
Always build it like you'll never go back into it again but always plan as though you will. Aircraft mechanics have this same philosphy. Fix it right the first time but always do so to help the next guy wether this will be you next week or another owner 50 years from now.
Part of every effort must be some form of preservation
Old 09-15-2018, 11:14 PM   #16
CUDA8U
CUDA8U's Avatar
acid dipping is another option once its apart
Copyright ©2000 - 2019, vBulletin Solutions Inc.
