Old 09-08-2018, 10:41 AM   #26
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: 350 Heating Up at Stops
What does your coolant look like? Are you running plain water or coolant mix?
Even if it does not get cold where you live to worry about freezing you need coolant mix for the corrosion protection. If the water is brown or the coolant is not bright green, flush the system before you do anything else. Scale and sludge in the radiator and engine water jackets will rob you of cooling capacity.
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 09-08-2018, 05:37 PM   #27
Boog
Senior moment
Boog's Avatar
I agree with bumping the base timing up some. Then reduce idle speed and readjust carb. Use manifold vacuum for the dist too. This should help to reduce engine temp and actually make the truck more responsive as well and use less gas too. Reducing idle speed will lower the trans fluid temp thereby reducing the heat load on the radiator.
Boog
69 Chevy stepside, 358/T350, 4.10 posi, 4.5/4 drop, rallys, poboy driver
09 Yukon SLT 4wd, 06 GMC crewcab Z71 5.3, 4.10
All GM..'nuff said,
Member of Jr Nation 88
Boog is online now   Reply With Quote
Old 09-14-2018, 03:11 PM   #28
cebra
Originally Posted by 68 P.O.S. View Post
Good deal on the shroud, that has a huge effect on cooling. Are you sure the rad is good to go? A 4 row should be plenty. Could be clogged just enough to reduce it's efficiency maybe. The rad is the main part of your cooling system, do you know anything about yours?
Bump your timing back up to 12 or 14 and readjust your idle. If you trust your temp gauge that's good enough for me. You can get an IR thermometer to double check it.
Yes, check your vac advance. Make sure the weights move freely & are lubed and make sure the vac can diaphragm isn't leaking or blown out. Easy check...hook it up to manifold vacuum and the idle will jump noticeably. If it doesn't, the vac can is bad or you already had it hooked up to manifold.
Perhaps on the radiator, it looks very new and clean and it never heats up besides when it is stopped. I may have to bite the bullet and have it pressure tested. I set the timing back up, no change their in temp less it may heat up slightly faster. The vac advance should be ok as I put a new distributor on it a few months back, can test that as well though just to make sure.
cebra is online now   Reply With Quote
Old 09-14-2018, 03:22 PM   #29
cebra
Starting to wonder about the radiator as I have tried everything I can think of and/or have read on here. My coolant is 50/50 and looks clean. I have emptied the radiator about once a month for the last 6 months battling this issue. The flex fan vs the clutch fan didn't change anything for me. The clutch fan is pretty far into the shroud where the flex was not but neither fixed the issue. How much does it generally cost to get a radiator pressure tested and will this tell me if the flow is sufficient or if it just has a leak (I know it doesn't)? Thanks for all the suggestions.
Old 09-14-2018, 04:36 PM   #30
Stocker
20' Daredevil (Ret)
Stocker's Avatar
It's possible that one problem was exchanged for another, and the results ended up about the same. What I mean is:
You started out with a crappy (my opinion) flex fan. It sat in or near the end of the shroud where it should, but its poor design allowed overheating.
Your new clutch fan can't properly do its job if the fan sits too far into the shroud. Instead of pulling air through the radiator, air is simply passing around the fan, between the fan and the shroud.
If you used a spacer (such as the one your flex fan had) with the clutch fan, that might be the problem. The fan clutches I have seen do not use a spacer. Remove the spacer and the fan will be better positioned in the shroud. Probably already posted but the fan should sit at the end of the shroud, roughly halfway in & halfway out.
Any chance you can post a pic or two showing the placement of the fan?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 09-15-2018, 06:48 PM   #31
Andy4639
Orignal Goof member
Andy4639's Avatar
Thumbs up Re: 350 Heating Up at Stops
One thing that hasn't been mentioned. Seal off the radiator so the air has to pull through it and not around it. Air is like water it flows to the easiest path. If you have gaps between the radiator and support and shourd close them up with some type of sealer. I use the black foam to seal off around it. It will work wonders for the cooling effect.
Timing will also help if it's not set right.
https://www.usplastic.com/catalog/it...SABEgKt_vD_BwE
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is online now   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
