Old 09-13-2018, 10:54 PM   #1
ZEKE68
ZEKE68's Avatar
Grindie feeling when you turn wheel?
Which is going to cause the grindie feeling when you turn the wheel with a power steering setup, is it the pump or the gearbox? Can you tell?
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 09-14-2018, 02:37 AM   #2
OregonNed
Long time Chevy fan
OregonNed's Avatar
Re: Grindie feeling when you turn wheel?
Interested to hear opinions as mine is slightly the same way. I'm assuming its maybe a bearing near the wheel?
1968 Chevrolet C/10 LWB - 327, TH350
OregonNed is offline   Reply With Quote
Old 09-14-2018, 10:01 AM   #3
68is4me
68is4me's Avatar
I would check steering column bearings. I think mine sounds and feels a little grindy too. I think mine is coming from the upper bearing in the column.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 09-14-2018, 10:44 AM   #4
ZEKE68
ZEKE68's Avatar
This feels more like a hydraulic pulsation kind of vibration. I do have a leak on my pump reservoir, and I read this morning that you can also suck air in the leak. I am going to replace the pump, but I am afraid the gearbox may be a problem also.
Old 09-14-2018, 05:56 PM   #5
my67c20
I second the hydraulic pulsation, however my feeling is that the pump is running to slow. Does not happen a few rpms higher than idle, so I think i need to speed the pump up. Larger pulley on crank, or smaller pulley on pump. Although if it is the steering column bearings, they are easy to replace. LMC had them. The lower one may have ground a groove in the steering shaft, so you might have to find someone to weld build and grind.
my67c20 is offline   Reply With Quote
Old 09-15-2018, 12:26 AM   #6
70 cst
70 cst's Avatar
I'm interested in this info as well. Been having the same issue with mine.
70 cst is offline   Reply With Quote
Old 09-15-2018, 01:46 PM   #7
HO455
HO455's Avatar
I would get a pair of mechanic's stethoscopes and have a friend turn the wheel back and forth while I listened to the various components. Don't for get the lower steering column bearing. (Which where my bet is placed. They fail or come loose at times). If you can feel the grinding there should be no problem hearing it with a stethoscope. I have also had some success using a wooden dowel (instead of the stethoscope) to locate those evil sounds.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Copyright ©2000 - 2019, vBulletin Solutions Inc.
