10-27-2017, 04:44 PM | #1 |
Radiator clearance
Hello all.
I am building a 47 chevy. I am currently I am building the motor. Its a 350 SBC Does anyone know if there is enough clearance for a LWP with an electric fan and stock firewall? I already have the Long water pump and all the brackets for the power steering and alternator. |
10-27-2017, 05:37 PM | #2 |
Re: Radiator clearance
I don't remember what pump I had on mine when I had the 350 in it.
Here is a chart with all of the small block outside measurements on it that might help. http://www.enginefactory.com/chevdimensions.htm
10-28-2017, 04:17 PM | #3 |
Yes there is room, just keep the motor back. I used long water pump, HEI and no firewall mods on 3 different trucks 47-53, and enough room.
10-28-2017, 06:25 PM | #4 |
Good advice there, some guys want to push the engine too far forward because they want lots of firewall clearance.
10-28-2017, 10:18 PM | #5 |
When placing the motor I set it as far back as I can and install the distributor and valve covers to make sure I can remove them before I weld the mounts.
10-29-2017, 08:26 PM | #6 | |
Don't be like me. Slam that sucker as far back as you can remove the dizzy / intake manifold / heads, then build the rest around that placement.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
10-30-2017, 08:56 AM | #7 |
LWP fits with the 350. That's what is in my 1949 AD. The distributor cap just about touches the firewall. I'd say I have 2" of gap. You'll need all the space you can get up front to fit the radiator. The other change I did for myself was I set the radiator into the core support to give myself some fudge factor. The radiator sits against the X cross on the core support.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
10-30-2017, 03:43 PM | #8 |
My 49 has a SWP, but you can see there is lots of clearance. Though the distributor is a small Mallory, a larger HEI would fit with a single 4 barrel instead of the tri-power. Engine is about as far back as you can go & still be able to remove the distributor & valve covers.
Pics of Finished 49 AD: https://www.flickr.com/photos/103194...7686536275403/ Pics of build process: https://www.flickr.com/photos/103194...57684031425944 |
