03-18-2017, 03:57 PM | #1 |
dennys driveshaft
I was looking at denny's driveshaft , i was wanting to get new shafts made and upgrade to a 1350 series joints and upgrade the tranny yoke and the pinion yoke as well
but can i use the slip joint style rear shaft for my 72 Fleetside with coil spring rear end?? anyone else running a Dennys drive shaft two piece
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
03-22-2017, 06:46 PM | #2 |
Re: dennys driveshaft
bump
03-22-2017, 07:31 PM | #3 |
I would save the money, I have grippy tires 275/60/15 M/H 4200 stall with trans break and still running the 1310 joints I wouldn't worry unless your dead hooking .
03-23-2017, 10:31 PM | #4 |
Fabricate till you "puke"
Look at the 3/4 ton pcs, on the driveline....my longhorn does run the slip in the middle, with 1350 joints. The old longhorn is leaf springs, but if you look at the 3/4 ton coil set up....on an 8 ft box truck, it will have the slip in the middle the 1/2 ton trucks , had the rubber hanger in the middle, with no slip yolk....not the best deal at all. I would talk with Dennys, on your app, & see what they have to say? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
