Old 11-19-2018, 03:20 PM   #1
hevy_chevy67
hevy_chevy67's Avatar
C50 Cab Differences
Was wondering if anyone could tell me the differences on a cab from a C50 to a C10? From a quick glance it looks like the only thing that is really different is the front fenders/clip. Doors look the same to me. Hood is interchange-able? Thanks in advance.
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e
1970 Chevrolet K5 Blazer - Project
1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4
1969 GMC Suburban - 5.3 LS, 4L60e
hevy_chevy67 is offline   Reply With Quote
Old 11-19-2018, 03:40 PM   #2
Clyde65
Clyde65's Avatar
Re: C50 Cab Differences
Cab mounts and trans jump is all I believe.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-20-2018, 12:36 AM   #3
Captainfab
60-66 Nut
There is no trans 'hump' as it is just flat across. Then there is an extra brace across the lower part of the firewall on the engine side, plus I believe the '60-'66 medium duty cabs all have the '60-'62 front cab mounting location. Other than that, the cabs are basically the same.
Old 11-20-2018, 04:00 PM   #4
Duncan K
Anyone ever put a C50 cab on a C10? I'd be interested to see how much work it would be
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 11-20-2018, 08:08 PM   #5
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Where the lower inner fender bracket is longer but is a bolt on item.
The additional brace as mentioned above. 100+ spotwelds to drill out.
Hole beside the seat drivers side for the vent for the power brake booster.
Look for a bolt in front transmission tunnel . You can cut out one from a light duty cab and bolt it in.
Additional firewall hole on earlier for hydraulic clutch.
Old 11-21-2018, 09:45 AM   #6
60-66
60-66's Avatar
This is also used on a 10 series with power brakes.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
