03-15-2017, 05:27 PM | #1 |
Horn Part Info needed
My horn used to work, then one day it stopped. I noted that when I changed the ignition lock cylinder and was putting the wheel back on I depressed the plunger on the canceling cam with the screwdriver and got a pretty big spark... I think that was when it stopped working.
Anyway, I wanted to get it working again so started to tear down the column, when I got to the turn signal switch I found a chard and small bit of copper where the plunger and spring are supposed to be, I yanked it out with some pliers. Now I am trying to find the part # for that plunger and spring but am coming up short. Can anyone help. Here are some pictures: |
03-16-2017, 07:24 AM | #2 |
Don't Crush em Restore em
Re: Horn Part Info needed
I believe they used to sell that part in the Help section of the auto parts stores.
http://www.oreillyauto.com/site/c/de...1&keyword=horn
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually |
03-18-2017, 08:28 PM | #3 |
http://www.ebay.com/itm/Turn-Signal-...FYqnmh&vxp=mtr this the part your looking for, order in non tilt. & tilt set up. LMC has them too / Classic Parts 73-87 / As said Dorman help scction
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 03-18-2017 at 08:46 PM. |
Tags |
copper, horn, turn signal switch |
