03-15-2019, 12:02 PM | #1 |
Pros and Cons of fuel return line...
So my street-ready restoration project is nearing some final details. It's a 72, but I don't think the tank is original because it was my understanding that 72 had a vent line on the top of the tank, and mine certainly does not.
However, it DOES have a return line that is currently just hanging out in the engine bay, and pukes fuel if you fill the tank up all the way. I assume it was originally hooked to a fuel pump with a return line, but that fuel pump left eons ago with the old engine. Current fuel pump has no provisions for a return. I've heard of people hooking up the return line to a "T" fitting with a small orifice, and this logic makes sense. I can certainly see this eliminating vapor lock at the carb. Am I more likely to get vapor lock from tank to pump, or pump to carb? So my options would be to just plug the line, replace the fuel pump with one designed for a return line, or hook it up near the carb with a "T" fitting.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
03-15-2019, 03:06 PM | #2 | ||
"I ain't nobody, dork."
Re: Pros and Cons of fuel return line...
I eliminated the return line on my 1972 GMC C15 and capped it off at the tank. I left the EEC hooked up and use it as a vent along the passenger side frame rail. I also switched to a vented fuel cap, just in case.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
03-15-2019, 06:56 PM | #3 |
Who Changed This?
Vapor lock occurs in the suction line from the tank to the pump. If it were mine, I'd use the recirc line style fuel pump. I have a small booster electric fuel pump to pressurize the fuel pump suction line to reduce vapor lock, since my truck does not have a recirc line.
03-15-2019, 06:59 PM | #4 |
I would keep it. You could cap it off and make a vent out of it like gasoline said. If you ever decided to do an grade in the future and needed more fuel you'll already have a return line.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
03-20-2019, 10:20 PM | #5 | |
03-21-2019, 01:58 AM | #6 |
I'm restoring mine without the return line, which is 71 prior. Takes a different gas cap than 72 too. It didn't have a return when I first got the truck, and never locked up. If it vapor locks I guess I'll need new from the sender to the carb.......Fun.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-21-2019, 10:55 AM | #7 |
On my 72 I installed an Edelbrock fuel pump that doesn't have a return line. All I had to do was cap off the return line and add a vented gas cap.
72 C10 lwb fleetside -stock 350/350 combo |
03-21-2019, 01:26 PM | #8 |
I wonder how many of "us" don't have a return line and experienced vapor lock?
03-21-2019, 03:31 PM | #9 |
Not it
03-21-2019, 05:09 PM | #10 |
Who Changed This?
My '70 does not have a recirc line, and if it gets hot enough it will vapor lock. Running the electric fuel pump to pressurize the fuel to the pump helps. It was hot out, but I wasn't even using the AC. It's why I'm nailing every opportunity for cooler running. That specific case, the fan clutch had given up the ghost, though.
03-21-2019, 06:45 PM | #11 | |||
Gary
03-21-2019, 11:20 PM | #12 | |
03-22-2019, 09:45 AM | #13 |
My experience was the same as GASolene71, but that was in the days before ethanol
was added to everything. It is much more difficult to drive anything carbed now. My truck Will vapor lock if it gets in ANY town traffic,( two red lights and party over) After finding a alcohol free fuel source it has no issues at all! But it's a giant PIT* to have Two stations within 40 miles to fuel from. All the Best, Dirk |
03-22-2019, 02:00 PM | #14 | |
03-22-2019, 05:34 PM | #15 |
71Chevyshortbed402
The puregas site is good and accurate for the most part in Colorado. I'm curious about the EEC lines and routing also, My 71 350 has the carbon canister and lines but not the return line at the pump. If I can make sense of it, some repurposing may be in order! it would be great to refuel anywhere and have a drivable truck in traffic! |
03-22-2019, 08:11 PM | #16 | |
03-23-2019, 07:54 PM | #17 |
I guess that's why my 71 doesn't have a return line !
That's for the info. It's one more piece of the puzzle. All the Best, Dirk |
03-23-2019, 11:30 PM | #18 | |
I'd like to pass on one that's for sure. If there's something to ethanol content, I'll never drive this truck long distances anyway. But then we're at the mercy of how long low-ethanol remains available.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-23-2019 at 11:39 PM. |
03-24-2019, 12:08 AM | #19 | |||
Gary
03-24-2019, 02:41 AM | #20 |
Thanks Gary
