Old 01-18-2020, 10:53 AM   #1
clay68c10
clay68c10's Avatar
Motorhome Tilt Column
Sold to SoCo
**SoCoC10 is first in line as he expressed interest previously***
$250 local. Prefer not to ship at this time, I don't have a good box for it right now.
Please respond in thread only per board rules, first "I'll take it" gets it.
Selling a motorhome tilt column. From a mid 80s GM chassis
I moved the NSS down so it's a bolt-in for your 67-72;
I used my multi-meter to adjust it, you may need to fine tune it after install.
Turn signal has no lever
Turn signal switch is tight and cancels as it should
Includes the cancel cam
The gray illumination wire is original length
Includes a long pigtail for the Neutral Safety/Reverse switch
Tilt mechanism is tight and smooth.
The 4 bolts in the tilt mechanism that typically loosen over time have been removed and reinstalled with lock-tight.
Tilt pivots were cleaned and lubed when removed to tighten the bolts.
The bottom bearing was cleaned and greased
The upper bearings were cleaned and greased
The shift indicator bulb was replaced and tested OK, it has the green shade on it.
Shifter lever end (inside column) is good, pivot is average
Shift arm and adjuster lever have nice chrome, they shine up well.
The finish on it is OK, great for a driver. Some scratches as pictured. It would probably buff out nicely.
I will include a new GMC Paul's gear indicator
You will need to add your dash and firewall gaskets, as well as the firewall plate.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-18-2020, 10:58 AM   #2
clay68c10
clay68c10's Avatar
Re: Motorhome Tilt Column
More pics
13 Tahoe LTZ
Old 01-18-2020, 10:59 AM   #3
clay68c10
clay68c10's Avatar
If you want any other pics let me know.
13 Tahoe LTZ
Old 01-19-2020, 02:12 PM   #4
SoCoC10
SoCoC10's Avatar
PM sent. I’ll take it.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 01-19-2020, 03:45 PM   #5
clay68c10
clay68c10's Avatar
Sold to SoCo
13 Tahoe LTZ
column, tilt, tilt steering column
