01-16-2024, 12:50 AM | #26 | |
Re: Caster Mod for pre 73
01-16-2024, 12:58 AM | #27 |
This is the correct orientation.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
01-16-2024, 11:54 AM | #28 |
I put the uppers back on the wrong side after I painted.
This is hilarious. |
01-17-2024, 11:31 PM | #29 |
You're not alone on that boat. The previous owner of my truck put the arms back on wrong after replacing ball joints. I didn't realize they were on the wrong side until I did the caster mod as well
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
