Old 10-12-2020, 03:45 PM   #1
kglowacky
inside mirror measurement
got new windshield with out a pre glued metal tab that holds the rear view mirror on. Anyone have a measurement on where I need to glue the tab on to the windshield. I figure center on the glass where the antenna is . just looking for a distance from the top of the windshield down. Thanks
kglowacky is offline   Reply With Quote
Old 10-12-2020, 06:29 PM   #2
65chevysub
65chevysub's Avatar
Re: inside mirror measurement
Does your windshield have the built in antenna? If so, center the tab between the lines. Bottom of the tab is about 5.5" I've enclosed some images that I hope will help you. Bottom of mount is about 5.5" from windshield rubber, and is about 29.5" in from lip of rubber on the left side.
65chevysub is offline   Reply With Quote
Old 10-13-2020, 07:17 AM   #3
I took my mirror an placed it between the visors and moved it so the visors wouldn't hit it when pulled up or down. I sorta just guessed on how far down to bring it. I'll try and get some meausrements later this morning.
Old 10-13-2020, 08:22 AM   #4
Rich84
Rich84's Avatar
I did the same thing. Just low enough to clear the visors.
One of my trucks is mounted in the tinted area and the driver visor hits it. Now I need to figure out how to lower it without breaking the glass.
Rich84 is offline   Reply With Quote
Old 10-13-2020, 10:27 AM   #5
kglowacky
Thanks everyone this helps.
Old 10-13-2020, 10:49 AM   #6
truckin 79
I put mine just right below the tinted part of the window. I found a used Saturn Vue mirror that has direction and outside temperature. The closer to the top the easier to hide the wires. I like to know how cold it is when I get lost
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 10-14-2020, 01:11 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Up high in the tint strip so you can't see it thru the windshield
Old 10-16-2020, 06:59 PM   #8
Axle
Axle's Avatar
Same as above. The height of the mating mirror mount + a little bit to get it as high as possible.
Axle is offline   Reply With Quote
