Old 01-22-2014, 09:44 PM   #1
mlo714
mlo714's Avatar
How do I get rid of "spark knock"
I finally got my truck running a 7 out of 10. After a fresh carb rebuild, new HEI dist, new spark plugs. I run premium gas all the time. When I get on the gas it sounds like the the motor is going to fall apart. Just in conversation people tell me "that's a timing issue". How do I fix this? can I just advance the dist or retard?
mlo714 is offline   Reply With Quote
Old 01-22-2014, 09:49 PM   #2
CST10
CST10's Avatar
Re: How do I get rid of "spark knock"
You need to check the timing with a light to make sure it's on spec. With vacuum advanced disconnected first for initial setting. Then check with vacuum advance connected. I'm assuming you have a vacuum advance on it. Don't know what your engine is to give much more info.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 01-22-2014, 09:52 PM   #3
hugger6933
Spark Knock or "preignition" or if you can if you can remember the early 80's the term "labor knock" was also thrown about. those conditions all all from timing that is to high, retard the timing a little bit and it should all clear right up. Do you have the timing set with a light, or did you just set it by ear? Or static time when building [or working on] the motor just to get it going and then it was so close you wanted to try it. If you put a light on it did you set it at an idle or an all in type thing at a certain rpm? Jim
hugger6933 is offline   Reply With Quote
Old 01-22-2014, 09:57 PM   #4
mlo714
mlo714's Avatar
Its a '72 307 with a 2bbl carb. I am very new to doing this on my own. I havnt checked it with a light yet. I know the difference between advance and retard but that's about it. Ill check it this sat and try to retard it a little and see if it goes away. I put new plugs in it and didn't gap them. It was having the knock before the new plugs as well.
Old 01-22-2014, 09:59 PM   #5
mlo714
mlo714's Avatar
If I stomp on the gas it wont do it....its only under load at light-mid throttle.
Old 01-22-2014, 11:00 PM   #6
71 super
71 super's Avatar
Pull timing out and also better fuel, colder plugs all will help get spark knock out
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 01-23-2014, 12:57 AM   #7
70blackfish
its really bad for a motor, better gas. and check engine temp.
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 01-23-2014, 01:40 AM   #8
Ridgeclimber
Check the timing with a light or you can also use a vacuum gauge. With the idle turned up to about 1000 rpm, advance or retard the timing until you get the highest vacuum reading. Then retard the timing until the vacuum gauge drops 1 inch of vacuum. Then turn the idle back down. If it still pings it also could be a lean air fuel condition. What did you do to the carb?
Ridgeclimber is offline   Reply With Quote
Old 01-23-2014, 01:59 AM   #9
70LonghornCST
Moderator
70LonghornCST's Avatar
Like others have posted, retard the timing and check the fuel/air mixture needles on the carb...also verify the timing with a timing light.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 01-23-2014, 06:29 AM   #10
Grumpy old man
Grumpy old man's Avatar
Go back and start from the beginning ,
pull the plugs and gap them
set the timing with a light
a fresh carb rebuild does not mean it is correct just close ,many guys can tune a carb by "ear" I would imagine these steps should easily fix your issue .
Old 01-23-2014, 12:01 PM   #11
turp mcspray
turp mcspray's Avatar
This sounds to me like a vacuum advance issue. Unhook the advance, and then go for a drive. A lot of distributors have lots of vacuum advance (like 24 degrees) to make up for a really weak timing curve. If you set the initial timing for more advance than stock, the vacuum can may push it too far during light throttle, high vacuum, driving. If this is the case, you simply need to limit the vacuum advance. About 10 degrees is a good number for a performace type of timing curve.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 01-23-2014, 02:14 PM   #12
DT1
DT1's Avatar
Agreed, if the knock occurs just at low speed/part throttle, it's more than likely a vacuum advance issue. BTW...if it's a stock 307 with 2BBL you only need to run regular gas. You are just wasting your cash with premium. It will do NOTHING to improve economy or performance.
You might find this interesting...
http://www.consumer.ftc.gov/articles...ctane-gasoline
DT1 is offline   Reply With Quote
Old 01-23-2014, 02:54 PM   #13
Fitz
Retard the timing.
Fitz is offline   Reply With Quote
spark knock, spark rattle, timing
