05-22-2011, 01:14 PM | #1 |
Crossover steering questions.
I am getting ready to convert my truck over to cross over steering. I have the 2wd steering box, but it needs to be rebuilt. Ive done a little bit of research but have come up empty handed.
First question is how hard is it to rebuild a steering box? Somewhere along the line I picked up that you have to change the steering shaft little joint thing to a u joint style one? I need to know which one because of the splines. Any info on this would be greatly appreciated.
Professional hot glue and pop cycle stick engineer. 72 K/20 soon to be C/10, 454, Th400, 9” rear. 01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler. 78 Bahner 19’ jet boat, 460 Furd turd. |
05-22-2011, 02:11 PM | #2 |
Currently Blazerless
Re: Crossover steering questions.
I dont know about the rebuild, I bought a reman cardone unit when I did mine..I'm sure someone will chime in with what you need to know. I do know you dont have to change the splined stub..you can still run your stock intermediate shaft or you can buy splined u-joints from companys like Borgeson, Flaming River or Iditit. I do believe its a good idea to get rid of the rag joint though..I went with a Borgeson vibration dampining joint and could tell a Big difference.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
05-22-2011, 07:45 PM | #3 | |
Born Psycho
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
05-22-2011, 09:00 PM | #4 |
I have rebuilt one in my 85 that I had built and as long as you are careful and do it correctly you can. You do need to be mechanically inclined though
2004 Silverado Crewcab (Dark Spiral Gray) |
05-22-2011, 11:42 PM | #5 |
Thanks for the impute. I have the ability to do the rebuild as far as being mechanically inclined but I also see Jerrys point too. This is going to be my daily driver for a while and I don't want to risk it.
Blazerman- That is exactly what I needed to know. I'm going to check into one of the vibration units you mentioned. Can you tell me which one is the right one? If anyone else has anything on this please let me know.
Professional hot glue and pop cycle stick engineer. 72 K/20 soon to be C/10, 454, Th400, 9” rear. 01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler. 78 Bahner 19’ jet boat, 460 Furd turd. Last edited by modblacksmith; 05-22-2011 at 11:59 PM. |
05-23-2011, 10:24 AM | #6 |
Here is mine, you can see the Borgsen vibration dampning Ujoint and D slip shaft. Works awesome!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
05-23-2011, 12:19 PM | #7 |
[QUOTE=Burt4x4;4695484]Here is mine, you can see the Borgsen vibration dampning Ujoint and D slip shaft. Works awesome!
Thanks for the pic. Is that a stock pittman arm for a 2wd? I have a Dodge one that will give me about two inches of drop. I heard some were that it will fit but I haven't tryed it yet.
05-24-2011, 10:17 AM | #8 |
No it is not. It is out of a Big Jeep, Wagoneer. Ya know the big famly jeep wagon. I don't remember the year. WFO hooked me up with it. Had to drill open the TRE hole too fit 1Ton Chevy TRE.
I have a very low lift and I am running Crossover/Highsteer so the GM 2x4 arm was too long.. WFO Concepts made the Crossover/Highsteer PSC Motorsports made the Hydro Assist Works Awesome = one finger steering in the rocks (If I wanted too)
05-24-2011, 02:32 PM | #9 | |
Ive thought about doing the assist but I dont really need it.
05-24-2011, 10:43 PM | #10 |
Grease Monkey
I am running a Borgsen steering shaft as well. Love it. I am also running a crossover steering with a TJ drop pitman arm and heim joints.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
05-29-2011, 03:13 AM | #11 |
[QUOTE=Chevy1TonFun;4698705]I am running a Borgsen steering shaft as well. Love it. I am also running a crossover steering with a TJ drop pitman arm and heim joints.
Thanks for the info. How do you like your Irocs for street use?
05-29-2011, 10:10 AM | #12 |
Grease Monkey
Love them, except that my truck and heavy foot eats them up,
05-29-2011, 08:03 PM | #13 |
Haha, I have the same problem with my 35s, the front two are like brand new and the rears are about half tread.
05-30-2011, 01:55 AM | #14 |
are you guys just using a later generation chevy for the 1 ton front axles?
05-30-2011, 02:05 AM | #15 |
Yep, I got mine out of a 84 dually.
06-03-2011, 04:43 AM | #16 |
Junior Member
Im almost positive I read/heard that Jeep Cherokee XJs steering shaft (which has u-joints) will work to replace the rag joint. I need to verify...cause Ive got about 8 of them for sale...
72 K5/10/20 Hybrid 350, 465/205 44/14 bolt 35s, Detroit locker 89 XJ Pioneer, 4.5" 32s. 98 ZJ DD. Parting..87-01 Cherokees I bore throttle bodies-PM me for details! |
