Old 11-13-2010, 11:14 PM   #1
chev-obsession
chev-obsession's Avatar
700R4 crossmember
Do the 700R4 tranny's require a 700R4 specific crossmember? Or can you use a turbo 350 or 400 crossmember?
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 11-13-2010, 11:24 PM   #2
Mike Bradbury
Mike Bradbury's Avatar
Re: 700R4 crossmember
No you need one for the 700. It is a different length tranny, I have heard of some guys just unriveting the 350/400 cross member and aligning it with the 700 but I have never seen it in action. Now days they are ready made for many vehicles and are not too expensive.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 11-14-2010, 12:10 AM   #3
clinebarger
You do not need to buy a cross-member.
Slide the cross-member back & drill new holes in the frame, You can use the 3 speed mount, just make sure to use metric bolts in the transmission case, they are 10 X 1.50mm
clinebarger is offline   Reply With Quote
Old 11-14-2010, 01:16 AM   #4
Captainfab
60-66 Nut
Exactly....there's no need for any kind of special crossmember. You just need an auto trans crossmember for a '66-'87 truck. You will need the correct trans mount for the crossmember, ie: single stud, or two threaded holes. Of course you can always drill a couple holes for the mount if needed.
Old 11-14-2010, 02:08 AM   #5
LEEVON
LEEVON's Avatar
yes...but, but, but...
Keep in mind that re-drilling the upper holes for the stock crossmember is next to impossible. Also, you will not have access to your rear transmission pan bolts which is a deal breaker for me on any trans swap. I hate moving a crossmember just to drop a pan, and with the 700R4 you will need to drop the pan and check on your TV plunger stroke if you're doing it right.
These two reasons were enough for me to cough up the $50 for a CPP crossmember which bolts on the bottom of the frame rails and has much more clearance.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-14-2010, 10:47 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Make you own if you don't move your current one. I had a one made with dual humps for exhaust.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 11-20-2010, 01:57 AM   #7
chev-obsession
does any one have dimensions/specs for the cpp or other aftermarket cross member?
1965 c/10 swb
1969 c/10 lwb
Old 11-20-2010, 02:14 AM   #8
clinebarger
I use a foot long 13/32" drill bit to drill the top holes from the bottem http://alliedboltinc.com/product/13/...BIT~51766.aspx
Old 11-21-2010, 07:08 AM   #9
SSedan64
SSedan64's Avatar
X2...A lot cheaper than a new Crossmember.
SSedan64 is offline   Reply With Quote
Old 11-23-2010, 12:30 AM   #10
chev-obsession
Ok.... now let me ask this.....
Im running the baer rear disc brakes, its a short bed and running the 700R4, would I need to remove the e-brake crossmember? If so what would I need to do in order to add an e-brake? Or what is the solution to this problem becasue i know that some one has done this before.
1965 c/10 swb
1969 c/10 lwb
Old 11-23-2010, 01:49 AM   #11
Captainfab
60-66 Nut
Do your rear disc brakes have an e-brake? If so, you will need to fabricate something on the bottom of your trans crossmember for the cables, or else use the e-brake cable system from a '66-'72 truck. Member TR65 fabricated a trans crossmember for his truck to accomodate the e-brake cables. If you do a search, you should find it.
Old 11-25-2010, 12:09 AM   #12
chev-obsession
ok ill look for it and yes the rear calipers have ebrakes
1965 c/10 swb
1969 c/10 lwb
Old 05-07-2013, 05:53 PM   #13
ChevyJr
Junior Member
ChevyJr's Avatar
I hope this isn't a stupid question, but can you simply flip the ebrake crossmember upside down? It should still serve the same purpose right? I am also doing a 700r4 conversion and would like to keep the original ebrake crossmember if possible. Even if that means sliding it further backwards and finding new cables at new lengths.
ChevyJr is offline   Reply With Quote
Old 05-09-2013, 09:37 AM   #14
chev-obsession
hey man, I tired flipping the original e-brake bracket at first. its located about the right length but the trans hung down way to low (bad angle) so I just went down to the wrecking yard and bought a trans x-member from like a 71 1/2 ton bolted it in and trans sits near perfect. as for the e-brake stuff I haven't got that far yet lol
1965 c/10 swb
1969 c/10 lwb
Old 05-09-2013, 12:04 PM   #15
dwntwn
dwntwn's Avatar
You can use a stock crossmember if the transmission mount attaches at the tailshaft like in Persh's picture.
http://www.persh.org/images/65Pickup/Trans_Xmbr4.jpg
What I ran into with my 700R conversion was the transmission mount was further forward on the transmission.
This location interfered with the pan, so I trimmed the front of the crossmember—mainly because my truck had the parking brake assembly attached to the rear of the crossmember and I didn't want to lose that provision.
If your transmission mounts at the rear, it is true you can use a stock crossmember, and depending on your parking brake setup will have to either attach it to the crossmember or use the later style like Captain Fab suggested.
If you want the crossmember with the parking brake attachment already done, Bowtie Overdrives has one for $175.
I decided I didn't like the modified crossmember in mine so I went with the $79 CPP one. And while I'm doing it, using the later style parking brake setup.
Parking brake assembly:
I have a '70 c20 longbed parts truck in my yard. I don't know if the parts I removed are available aftermarket or you would need to go to a junkyard, but I can say with my install, all I need to buy is the intermediate cable. LMC carries it for $9.95, and it is the same part number '64-72, so even though the parking brake is different (hand brake vs pedal) the intermediate cable is the same.
I agree the mechanism is simpler, but I don't know if I would have gone to the trouble of converting to the later style if I didn't have the parts truck sitting 50 feet from my garage.
1966 c10, short fleet, 402ci 700r4
1988 r20 Suburban 454ci tbi, th400 (12v Cummins soon)
1980 shovelhead, hardtail, open primary
1998 FXDWG
dwntwn is offline   Reply With Quote
Old 06-06-2014, 07:15 AM   #16
lesauto
lesauto's Avatar
Smile Re: 700R4 crossmember
Thanks for the info dwntown I'm ordering 1 from bowtie overdrive they look really nice. And since I have torsion bars on my 62 I don't have a lot of oppotions I could make one but it would not look near as good..
lesauto is offline   Reply With Quote
Old 12-28-2018, 12:19 PM   #17
KMAT
Please somebody correct me if I'm wrong but aren't the crossmember for a turbo 350 and a turbo 400 different? And I'm not sure what of the two Transmissions were in this truck prior to buying it but my crossmember does not seem to want to bolt up properly to the transmission. Is it possible that I have the wrong rubber mount peace?
KMAT is offline   Reply With Quote
Old 12-28-2018, 12:56 PM   #18
Mr_Rich
Mr_Rich's Avatar
Back when I still had my '69 Firebird project I was planning a 700R4 swap and my research turned up the fact that T400 trans and 700R4 trans have very similar mounting dimensions; within a fraction. The T400 crossmember is built so that it used the same T350 mounting holes on the frame. I still have that support/ crossmember for sale since my plans have changed. I don't know if it will work on trucks though. It's 31 1/2" wide and 30 1/2" between mounting holes.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 12-28-2018, 11:46 PM   #19
Captainfab
60-66 Nut
No the crossmember is the same, just a different set of holes in the frame to bolt it in. A pic might help troubleshoot your issue.
Old 12-29-2018, 03:17 AM   #20
KMAT
Okay then i must have something else going on here then, mabey crossmembers been altered.I better pull it back out and have a better look see at it. THANKS for your response, will have a update on issue couple days.
