Old 05-21-2012, 10:47 PM   #1
Jemo
I really need some help with Edelbrock carb
I drove my truck a short distance for the first time tonight. The throttle cable is way too sensitive and the TV and throttle cable just don't look lined up right with the bracket I bought.
I bought Edelbrock specific cable brackets and geometry correction brackets. Seems like the brackets are too much at an angle and like I said, the throttle is way too sensitive. Haven't put the throttle return spring on yet either but am getting to that. Does anyone have any ideas on how to fix this?
Here is the carb bracket I bought:
http://www.jegs.com/i/JEGS-Performan...rentProductId=
Here is the correction bracket:
http://www.summitracing.com/parts/SUM-700203/
'59 Big Window Fleetside
Jemo is offline   Reply With Quote
Old 05-22-2012, 05:03 AM   #2
gysgtc
Re: I really need some help with Edelbrock carb
I can't answer that question but from the picture you have the distributor vacuum advance line on the wrong side of the carb unless you truck has anti pollution. It should go on the right.
gysgtc is offline   Reply With Quote
Old 05-22-2012, 04:37 PM   #3
Jemo
thank you. Fortunately, this is a LS motor so it does not have a distributor. Anyone else have any ideas?
Old 05-22-2012, 09:18 PM   #4
clinebarger
Without return springs the throttle will be real "jumpy" & dangerous.
The bottom line on the TV system is your using mismatched stuff from different vendors.
Fabrication/moving the TV cable bracket is going to be necessary to get it lined up with what you have.
Dont leave it like that, The TV cable inner wire will saw into the plastic end.
Is this pic before you did the cable adjustment procedure, I only ask because the adjuster is all the way in?
clinebarger is offline   Reply With Quote
Old 05-22-2012, 09:22 PM   #5
Jemo
Clinebarger,
I haven't adjusted it at all. I'm totally lost on how to do this. The throttle cable is very questionable too. Is there a bracket and geometry correction linkage I can buy that will work out of the box?
Could I buy you lunch and have you show me?
Jeff
Old 05-23-2012, 07:35 PM   #6
clinebarger
Clinebarger,
Jeff
It would be cheaper to buy a kit that works than paying me to fix what you have.....
http://www.bowtieoverdrives.com/cata...php?ITEMID=213 You will also need the $10 throttle cable bracket.
STOP driving it untill this is sorted out!
Old 05-23-2012, 09:10 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Agreed... don't drive it again, until you figure out the correct geometry for the TV cable, and get it adjusted right. You WILL damage your tranny if you keep driving it.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-23-2012, 09:52 PM   #8
Jemo
Thanks guys. Please be sure, I am not driving the truck. I drove it on the trailer once and that's it. I did more research today and found a kit I'm going to get. Clinebarger mentioned that I'm mixing and matching parts so I checked with Lokar and they have a complete set-up and since I already have a Lokar throttle cable, I may as well make it complete since it's known to work together. The adjustment for the TV cable is also right up my alley so I'm going to purchase it.
Make final adjustments by holding throttle to wide open and pulling the kickdown inner cable as tight as possible. Slide cable stop up against Lokar Cable Slide Fitting and tighten allen set screw. When the kickdown is properly adjusted you should be able to open the throttle to wide open position and there should be no slack in the kickdown cable.
