Old 01-11-2013, 08:39 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Educate me: Steering stabilizers on 4wd, all years?
What year 4x4s had steering stabilizers? '72 only? Pics (Thanks Tom Korinek) show what I believe is an OEM stabilizer bracket ('72 Blazer) on the tie rod: the stabilizer attaches to a plate affixed onto the Dana 44 as shown. Was the stabilizer offered for all years?
Old 01-12-2013, 09:23 AM   #2
Re: Educate me: Steering stabilizers on 4wd, all years?
'72 was the first year,as far as I know.
Old 01-12-2013, 10:46 AM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Interesting...learn new things here all the time. I guess that bracket is one year only deal then. The '72 model had several one-offs: doors, door panels, window regulators, tow hooks, aux tank, SS tailgate handle cover, rear view mirror...
Old 01-12-2013, 12:40 PM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
1972 3/4 ton 4X4 - another hard part to locate is the rear brake cable (one year only) for a eaton Ho52. I been holding onto a NOS one for a while, cannot find a match or suitable replacement anywhere.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 01-12-2013, 12:44 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Dave that's good to know. Would that be the e-brake cable then? I've got a nice spare '72 K20 frame so may need to keep an eye out for that part....
Old 01-12-2013, 02:08 PM   #6
too much stuff
Roadtrip!
too much stuff's Avatar
Since the front is a dana thing, and if 72 was the first year, wouldn't it be the same from 72 up to late 70s-early 80s?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-12-2013, 03:29 PM   #7
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
From what i recall 72 was the first year and in 73 the tie rod did'nt have the bolt on bracket but a hole made in the tie rod
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-13-2013, 11:53 AM   #8
^ Yep ^...And,the axle end is a bracket welded to the housing
Old 01-13-2013, 08:40 PM   #9
sboris
sboris's Avatar
So are these after market? Seem old.. Mounted on a 70chassis. The one on the tie rod seems the same..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 01-13-2013, 09:00 PM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The tie rod bracket looks like a GM piece.
Old 01-13-2013, 09:51 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
^^ Yup. And the axle bracket is aftermarket.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 01-13-2013, 09:57 PM   #12
sboris
sboris's Avatar
Interesting!
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 01-13-2013, 10:25 PM   #13
Probably the tie rod bracket was taken from a '72 at some point
Old 08-14-2013, 11:35 PM   #14
AHowe88
Digging up an old thread here...
I have a 72 without any steering stabilizer, or the hardware for it. Where some made without, or was it just taken off at some point?
I'd like to add a stabilizer, without the hardware on the truck, what are my options? The ones I looked at don't come with the mounting hardware.
AHowe88 is offline   Reply With Quote
Old 08-14-2013, 11:44 PM   #15
DeadheadNM
Carpe manana
DeadheadNM's Avatar
First thing - look at your front (Dana 44?) axle and see if it has the affixed bracket to attach the wheel end of the stabilizer (see first pic above). If so, should be a 72 front axle and all you'd need is the tie rod bracket. If not, I'd question an axle swap to an earlier model Dana 44 that would need some extra mounting hardware.
Old 08-15-2013, 12:15 AM   #16
Spartan
Spartan's Avatar
My 69 has one. looks og...always thought it was factory. d44 closed knuckle.
still learning.
i guess ill remove it!
'69 K20 350/4 speed/Rockwell/D44/HO52.
"orange rhymes with door hinge"
Spartan is offline   Reply With Quote
Old 08-15-2013, 08:18 AM   #17
D.PASSMORE
One of the First
D.PASSMORE's Avatar
still learning.
Like to see a picture.
To verify the year of the axle, you can check the date on the ring gear. If its original ring and pinion, it will be real close to the installation date of the OE D44.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 08-15-2013, 08:38 PM   #18
Spartan
Spartan's Avatar
I'll be heading down to the farm over the weekend and remember to flash some photos. It's a closed knuckle d44 so I'm guessing the stabilizer was bolted on somehow... pics will tell all c
Cheers!
Nim
Old 08-15-2013, 09:59 PM   #19
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
So is that just a shock? I ordered from rancho what I thought was the right charged cylinder but it arrived with threaded rods on both ends.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 08-15-2013, 10:02 PM   #20
67swb72klb
67swb72klb's Avatar
I thought that 69's were open knuckle ?
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 08-15-2013, 10:10 PM   #21
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The correct stabilizer for 72 is just like a shock that comes with loose bolts that affix the ends to the brackets at the 1) axle (welded in place by Dana) and the 2) tie rod - just like the first pics above
Old 08-19-2013, 11:12 PM   #22
Spartan
Spartan's Avatar
okay... I went out to the farm and took pics over the weekend.
Cant upload photos, at least not the same way I used to and I'm not computer literate so I'm gonna just throw my hands up. Kind of a bummer tho because pics say it all.
Here's what I learned about my truck. The axle is factory. I assumed the stabilizer was because it all has the same rust (LOL). It is bolted on tho and the plate that has the stabilizer bolted to it also has the driver side shock bolted to it so it serves dual purpose as stabilizer and shock mount and bolts to the axle outboard of the spring perch. I find it kind of interesting that it shares a bracket with the shock but it is a beefy stamped u-bolted item.
I guess I wont remove it after all. Looks like it was meant to be there.
c
Beers!
Nim
Old 08-20-2013, 02:34 AM   #23
68shortfleet
David, I found a shop recently that will make cables for almost anything and custom cables too. Might take me a little bit to dig up their info, PM me if you are interested in it. I ordered cables for my 68 swb from them and they fit perfectly and are made in the USA.
68shortfleet is offline   Reply With Quote
Old 11-12-2015, 09:16 PM   #24
V6GMC
V6GMC's Avatar
I Have A 1971 Chevy Dana 44 3/4 ton Front Axle With The Factory Mount On The Axle Tube.
V6GMC is offline   Reply With Quote
Old 11-13-2015, 01:48 AM   #25
DeadheadNM
Carpe manana
DeadheadNM's Avatar
A 1971 manufacture date would be potentially be correct for the 72 model year depending on the month...
