Old 03-24-2020, 02:34 PM   #1
KyFarm
Active Member
KyFarm's Avatar
Dana 44 yoke question
Having the driveshafts modified to fit the new placement of the T/C. Noticed a broken tab on the rear yoke, so I figure Id remove front and rear and replace. I think the front is ok though, tabs look really good but I figured Id ask here. Pics below.
Bigger question though may be that when I removed the yoke from the front diff oil began to seep out. Does the yoke hold the seal together? It certainly appears that part of the seal stayed with the yoke.
Thanks for any help.
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 03-24-2020, 05:48 PM   #2
BCOWANWHEELS
Re: Dana 44 yoke question
Change out the seal , its shot................ along with the yoke
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 03-25-2020, 01:35 AM   #3
Jcfcamaro
Jcfcamaro's Avatar
Torqking 4x4 is a good place for hard to find items.
Jcfcamaro is offline   Reply With Quote
Old 03-25-2020, 05:44 AM   #4
KyFarm
Active Member
KyFarm's Avatar
Might you have a link to a thread about changing that seal or can you give cliff notes?
Im assuming that involves disassembly of the diff to get to that seal from the inside?
Old 03-25-2020, 08:25 AM   #5
MJN
MJN's Avatar
If you can give some specifics about your truck that would help- what transfer case, etc. The differential pinion seal is easily replaced- no need to tear apart the differential. Just use a seal puller or similar and pull the seal out of the housing and then tap the new one in. I've always used a center punch to mark the pinion and nut position before removing it, its a Dana 44 you won't have to worry about a crush sleeve since they use shims to set the pinion depth.
Pull out the seal, tap in the new one, put the new yoke on and tighten up the pinion nut.
The service manual here, http://www.73-87chevytrucks.com/tech...ice_Manual.pdf
has torque specs in the back for the pinion yoke nut and transfer case yokes too.
Front pinion is 255 ft lbs.
https://www.northerndrivetrain.com/c...s_dana_44.html also has Dana/Spicer parts available along with yokes for your transfer case.
'51 South Bend Model "A"
'52 Dodge M-37-repowered with 283 SBC
'56 Chevy 3600 NAPCO
'74 Chevy Cheyenne Super K/20-fully restored on 37's
'72 GMC Sierra Custom k/2500- in progress
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
http://www.mtu4x4.org
http://www.nohrco.com
Old 03-25-2020, 10:29 AM   #6
BCOWANWHEELS
randys ring and pinion will have yoke and seal
Old 03-25-2020, 11:07 AM   #7
kwmech
Yoke looks fine. Take some sandpaper and polish the seal surface. If you do not have any lines left you're golden. Put some liquid teflon on the splines. Before new seal installation, put some light grease on the backside of the seal to hold the spring in place so it doesn't pop off when you shove the yoke onor pound the seal in. To drive the seal in tight use a 603010-12-or-14 race to drive it in square and tight. Slide the yoke in and tighten it down tight ---if you are using the nut over use a few drops of locktight on it
Old 03-25-2020, 07:36 PM   #8
KyFarm
Active Member
KyFarm's Avatar
great info, just what I needed. thank you all, and yes it is a dana 44 on front with the shown yoke but the leaky seal.
definitely getting a new yoke (not shown) for the back diff, as one of the tabs was nearly gone.
Now If I can get the driveshafts back before the whole city gets shut down I'll be happy. Had to get a new front driveshaft as there was noticeable wobble between the two parts. Rear is just getting shortened and updated.
again, thanks for the great info.
Old 03-25-2020, 10:39 PM   #9
57taskforce
57taskforce's Avatar
If you have grooves from the seal on the yoke you can also drive the seal a little further in the housing so you can get the lips in a different spot on the yoke. I’m sure you can also get a speedi sleeve for it as well. They can be spendy though.
'57 3100 350/700r4 4 lift 35x12.5's
'72 K/20 Cheyenne 350/SM465 557 paint http://67-72chevytrucks.com/vboard/s...d.php?t=662879
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
10 Camaro 2SS/RS l99 6l80e Aqua Blue Metallic #2399
57taskforce is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
