09-10-2020, 05:22 PM | #1 |
Rpo K46 Too much Air restriction for 327?
I found all the pieces to this hd air cleaner setup I am thinking about adding to my stock 67 build. I am looking at the rpo code and it states for all engines including the 283 but not 327. Would that be because it restricts too much air for it? It Has a 3.5 inch tube to the pre cleaner and 3 inch to the air cleaner. Would be pulling cooler air from the cowl which would be nicer I would think.
09-10-2020, 08:14 PM | #2 |
Re: Rpo K46 Too much Air restriction for 327?
Wow, I've not seen one of those before. I say try it out. A couple of 0-60mph test runs should tell you how it compares to a more standard setup. Maybe the thing to try is bypassing the pre-cleaner. What's inside of those things anyhow?
09-10-2020, 08:53 PM | #3 |
Not sure what's inside as I don't have it in my hands yet. I too thought of that just to keep restriction lower.
09-11-2020, 11:26 AM | #4 |
I think I would consider bypassing the pre-cleaner entirely and just running a hose from the cowl fitting to the air cleaner. Should be fine for your engine.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
09-11-2020, 12:04 PM | #5 |
That is really cool!
Are you mounting the cowl plenum on the right hand side of the cowl then to your air cleaner assy. ? I haven't ever seen this before, I wonder if something like this was available on the 67-72 generation of trucks? 3" all the way to your air cleaner should for enough CFM. for a 327, was this only available in years when the 283 was the big inch option? Have fun with your build! All the Best Dirk |
09-11-2020, 07:01 PM | #6 |
The red truck is a 67 factory with a 283 in it. I am going to mount it just as the factory did it but with my 327.
09-12-2020, 02:18 PM | #7 |
driving is in my blood
That air hose is way bigger then your carb throat. Should be fine.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
